-1
I used a script from here to setup rules that make sure user transmission-daemon can only send traffic via the VPN i use.
At least that's what the author says. I have troubles understanding the following output. For example, what does the line tcp spt:9091 owner GID match debian-transmission mean? Why is there no traffic on that rule?
Hint: My ethernet port is enp3s0 (like eth0).
$ sudo iptables -L -v
Chain INPUT (policy DROP 0 packets, 0 bytes)
 pkts bytes target     prot opt in     out     source               destination
  436 35225 f2b-sshd   tcp  --  any    any     anywhere             anywhere             multiport dports ssh
 1085  221K ACCEPT     all  --  tun0   any     anywhere             anywhere
 2913  923K ACCEPT     all  --  enp3s0 any     anywhere             anywhere
  112 12221 ACCEPT     all  --  lo     any     anywhere             anywhere
Chain FORWARD (policy DROP 0 packets, 0 bytes) pkts bytes target prot opt in out source destination
0 0 all -- any any anywhere anywhere
Chain OUTPUT (policy ACCEPT 4540 packets, 1267K bytes) pkts bytes target prot opt in out source destination
0 0 ACCEPT tcp -- any enp3s0 anywhere 192.168.100.0/25 tcp spt:9091 owner GID match debian-transmission 0 0 ACCEPT udp -- any enp3s0 anywhere 192.168.100.0/25 udp spt:9091 owner GID match debian-transmission 2263 202K ACCEPT all -- any tun0 anywhere anywhere owner GID match debian-transmission 12 2581 ACCEPT all -- any lo anywhere anywhere owner GID match debian-transmission 0 0 REJECT all -- any any anywhere anywhere owner GID match debian-transmission reject-with icmp-port-unreachable
bomben
  • 2,167
the rule:
iptables -A OUTPUT -d 192.168.100.0/25 -p tcp --sport 9091 -m owner --gid-owner debian-transmission -o enp3s0 -j ACCEPT
will ACCEPT the packet IF it is to any IP in the range 192.168.100.0 - 192.168.100.127 AND the protocol is tcp AND the source port is 9091 AND the packet owner is debian-transmission AND it is destined for the network interface enp3s0 ELSE go to the next iptables rule.
bomben
  • 2,167
Doug Smythies
  • 16,146
