A blown up image shows the cable snake on the left:
From the author's blog:
GNOME Shell
The GNOME shell bits to enable Thunderbolt 3 support were merged some
time ago and made it into 3.28. This means that the GNOME shell will
act as authorization agent and will automatically authorize new
thunderbolt 3 devices — if the user has administrator rights, is
currently logged in and the session is unlocked. It will also show a
little indicator (called the cable_snake by some) in the status
indicator section while devices are being authorized because the whole
authorization dance can take quite a while.
Correspondence from developer
I emailed the developer and this is our conversation:
There are users annoyed with Cable_Snake icon making icons shift left and right in the application indicator top bar. Is there a way to disable the icon but keep boltd running?
This was introduced via a change in the kernel/udev, but a work-around
laded in bolt 0.9:
https://gitlab.freedesktop.org/bolt/bolt/-/issues/156
There is an ubuntu bug open:
https://bugs.launchpad.net/ubuntu/+source/bolt/+bug/1892657
Currently not, GNOME Shell is hardwired to react to boltd's probing
setting. Best way is to update bolt.
Follow the author's blog for updates.
Some ideas of my own
I use the Unity interface where application indicators are right justified on the top bar so new apps opening and closing on the left are preferred and not a disadvantage.
For Gnome Users to prevent icons jumping back and forth the only band-aid I can think of is moving all icons to the right side. This can probably be achieved here:
If this works, then when the boltctl icon appears and disappears on the left side nothing "jumps around".
I've emailed the developer again on December 24, 2020 with a link to OP's problem and asked these questions:
- A) Is there an update to correct the problem?
- B) Is it possible to define a new cable snake icon which is 0x0 pixels such that even if it still reappears every few seconds the effect is invisible?
