I am trying switch to ubuntu and only want to use open source software. Should I tick "Install third party software" or should I install what I need manually?
Xell
If you would like to stick to running only open source software, then you will likely want to stay away from ticking the box. Not all third-party software is closed source, but not checking the box will give you the opportunity to first research the packages you need/want, then install them manually later.
