Summary:
I am unable to install Additional Drivers after upgrading from Ubuntu 18.04 LTS to Ubuntu 20.04 LTS. I receive the following error message:
Unable to install "Additional Drivers":
Error while installing package: installed linux-image-4.15.0-88-
generic package post-removal script subprocess returned
error exit status 1
System: Dell Precision 5510 Mobile Workstation, 32GB RAM, 1TB Samsung NVMe hard drive; dual-booted with Windows 7 Pro-64
Details:
If I try to rip out the package linux-image-4.15.0-88-generic manually, it fails. I am stuck. It also appears that I am unable to add/remove any other packages as well.
% sudo apt remove linux-image-4.15.0-88-generic
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
browser-plugin-evince g++-7 gir1.2-mutter-2 libargon2-0 libavutil55 libbasicusageenvironment1 libboost-chrono1.65.1 libboost-iostreams1.65.1
libboost-locale1.65.1 libcapnp-0.6.1 libcdio17 libdouble-conversion1 libdrm-dev libdvdread4 libebml4v5 libfluidsynth1 libgdbm5 libgfortran4 libglade2-0
libgmime-3.0-0 libgnome-desktop-3-17 libgspell-1-1 libgtkmm-2.4-1v5 libicu60 libip4tc0 libiptc0 libisc169 libisl19 libjson-c3 libllvm9:i386 liblwres160
libmagickcore-6.q16-3 libmutter-2-0 libmysofa0 libnfs11 libnss-myhostname libnvidia-common-435 libnvidia-compute-435 libnvidia-compute-435:i386
libnvidia-decode-435:i386 libnvidia-encode-435 libnvidia-ifr1-435 libnvidia-ifr1-435:i386 libperl5.26 libplacebo7 libpoppler73 libpostproc54
libprotobuf10 libproxy-tools libqpdf21 libraw16 libresid-builder0c2a libssh2-1 libtinfo-dev libtinfo5:i386 libusageenvironment3 libvlc5 libvlccore9
libx265-146 libx86emu1 libxcb-glx0-dev libxcb-render0-dev libxcb-sync-dev libxfixes-dev libxshmfence-dev linux-headers-4.15.0-99
linux-modules-4.15.0-99-generic nvidia-compute-utils-435 nvidia-dkms-435 nvidia-kernel-common-435 php-cli php-common php-xml php7.4-cli php7.4-common
php7.4-json php7.4-opcache php7.4-readline php7.4-xml python-cairo python-fasteners python-gobject-2 python-gtk2 python-lockfile python-monotonic
python-six python3-asn1crypto python3-oauth qt4-qmake socat ubuntu-web-launchers vlc-data vlc-plugin-video-output
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
linux-image-4.15.0-88-generic linux-image-4.15.0-99-generic
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 16.8 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 331573 files and directories currently installed.)
Removing linux-image-4.15.0-88-generic (4.15.0-88.88) ...
/etc/kernel/postrm.d/initramfs-tools:
update-initramfs: Deleting /boot/initrd.img-4.15.0-88-generic
/etc/kernel/postrm.d/zz-update-grub:
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
using custom appearance settings
Found linux image: /boot/vmlinuz-5.4.0-58-generic
Found initrd image: /boot/initrd.img-5.4.0-58-generic
Found linux image: /boot/vmlinuz-4.15.0-128-generic
Found initrd image: /boot/initrd.img-4.15.0-128-generic
/etc/grub.d/bin/grubcfg_proxy: error while loading shared libraries: libcrypto.so.1.0.0: cannot open shared object file: No such file or directory
run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 127
dpkg: error processing package linux-image-4.15.0-88-generic (--remove):
installed linux-image-4.15.0-88-generic package post-removal script subprocess returned error exit status 1
dpkg: too many errors, stopping
Processing was halted because there were too many errors.
When I check the installed linux-image packages, I get the following:
% aptitude search linux-image | grep -v ^p
v linux-image -
c linux-image-4.13.0-45-generic -
i A linux-image-4.15.0-128-generic - Signed kernel image generic
c linux-image-4.15.0-74-generic -
c linux-image-4.15.0-76-generic -
Bd linux-image-4.15.0-88-generic - Signed kernel image generic
H linux-image-4.15.0-99-generic - Signed kernel image generic
i A linux-image-5.4.0-58-generic - Signed kernel image generic
c linux-image-extra-4.10.0-28-generic -
c linux-image-extra-4.10.0-42-generic -
i A linux-image-generic - Generic Linux kernel image
v linux-image-oem-5.6 -
I am stuck. How do I rip this package out or fix what is wrong? I haven't done any package management myself. All I did was an "upgrade" from 18.04 LTS to 20.04 LTS via the Software Update widget.
TIA.
