the following problem is driving me crazy - I literally can't use apt right now because this issue appears whenever I try to update/upgrade/install a package (apt --fix-broken install ect. is not working either)
environment is arm64 ubuntu 64bit on my raspberry
sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libavdevice58 : Depends: libsdl2-2.0-0 (>= 2.0.12+dfsg1) but 2.0.10+5rpi is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I tried to find the package which is causing this issue / removing related packages but also this is not working
sudo apt-get remove libavdevice58
libavdevice-dev : Depends: libavdevice58 (= 7:4.3.1-4ubuntu1) but it is not going to be installed
or
sudo apt-get remove libavdevice-dev
libavdevice58 : Depends: libsdl2-2.0-0 (>= 2.0.12+dfsg1) but 2.0.10+5rpi is to be installed
I know that this issue is caused by packages I installed manually for emulation station but I don't know how to fix this issue. I tried to boot into recovery mode but until today I didn't figure out how to do this on the raspberry.
Let me know if any of you knows this issue or if there is a common way to fix it. If not I will most likely reinstall the OS.
BR Lukas
