I have an issue with HEIC thumbnails.
I can open heic files via the image viewer, however, I can't get the thumbnails showing.
when I try installing heif-thumbnailer by running
sudo apt-get install heif-thumbnailer
I get the following message:
The following packages have unmet dependencies: heif-thumbnailer : Depends: libheif1 (= 1.9.1-1~ppa1~ubuntu20.04.1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
What can I do to fix this?
UPDATE:
It gets weirder, as I noticed:
Some HEIC files do have thumbnails, but image viewer won't open them and Some do not have thumbnails, but the image viewer will open them...
Simon B
  • 1,296
As of September 2022 running
sudo apt-get install libheif1 heif-thumbnailer
instantly generated thumbnails for my heic images without the need to run any commands or restart anything :-) Works like a charm :-)
flob
  • 452
Below solution works for me. I'm using Ubuntu 20.04 and I used these two commands for .heic images dispplay issue:
Run: sudo apt install heif-gdk-pixbuf
Run: sudo apt-get install libheif1 heif-thumbnailer
