After installing AMD's GPU drivers here (specifically "version 20.20 for Ubuntu 20.04"), OpenCl doesn't work.
To install the drivers I unarchived the tarball and ran ./amdgpu-pro-install -y --opencl=pal,legacy --headless and sudo usermod -a -G video $LOGNAME.
The command lspci -nn | grep -E 'VGA|Display' properly displays the installed GPU: 01:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] [1002:67df] (rev c7)
But when I run clinfo I get an output of
Number of platforms                               2
  Platform Name                                   AMD Accelerated Parallel Processing
  Platform Vendor                                 Advanced Micro Devices, Inc.
  Platform Version                                OpenCL 2.1 AMD-APP (3110.6)
  Platform Profile                                FULL_PROFILE
  Platform Extensions                             cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
  Platform Host timer resolution                  1ns
  Platform Extensions function suffix             AMD
Platform Name Clover Platform Vendor Mesa Platform Version OpenCL 1.1 Mesa 20.0.8 Platform Profile FULL_PROFILE Platform Extensions cl_khr_icd Platform Extensions function suffix MESA
Platform Name AMD Accelerated Parallel Processing Number of devices 0
Platform Name Clover Number of devices 0
NULL platform behavior clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) No platform clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) No platform clCreateContext(NULL, ...) [default] No platform clCreateContext(NULL, ...) [other] No platform clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) No devices found in platform clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) No devices found in platform clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) No devices found in platform
After searching around I tried running sudo apt-get install ocl-icd-opencl-dev, but it was already installed.
Any help would be very appreciated. Please let me know if there is any information I could add that you think may be useful.
I have the same problem trying to use OpenCl (for mining) via ssh (despite I installed amdgpu-pro using the --headless option). If you experience the issue via ssh try to log in directly after boot and start the specific process there as a workaround. If it does not work and you installed amdgpu-pro via ssh try to install it directly.
Kytut
Attribution
First I tried to install the amdgpu software for the particular videocard, but I was not able to get that working successfully. Furthermore, the ./amdgpu-install and amdgpu-pro-install scripts froze the terminal for a significant amount of time. Hence, after some trial and error I followed the steps from this video, which explains the/a more detailed- process suggested in the answer by TurboSlayer in this question. I verified the instructions work by inspecting the output of both clinfo and rocminfo and observing the respective cards are indeed recognized in the output of both of these commands.
Code
# Source of commands: https://rocmdocs.amd.com/en/latest/Installation_Guide/Installation-Guide.html
yes | sudo apt update yes | sudo apt dist-upgrade yes | sudo apt install libnuma-dev yes | sudo apt install wget gnupg2 wget -q -O - https://repo.radeon.com/rocm/rocm.gpg.key | sudo apt-key add - echo 'deb [arch=amd64] https://repo.radeon.com/rocm/apt/debian/ ubuntu main' | sudo tee /etc/apt/sources.list.d/rocm.list yes | sudo apt update sudo reboot
Open a terminal after reboot and run:
yes | sudo apt install rocm-dkms sudo usermod -aG video $LOGNAME sudo usermod -aG render $LOGNAME echo 'export PATH=$PATH:/opt/rocm/bin:/opt/rocm/profiler/bin:/opt/rocm/opencl/bin' | sudo tee -a /etc/profile.d/rocm.sh
Wait till everything is installed and reboot again
sudo reboot
Verify the videocards are recognized with:
clinfo rocminfo
Next, one wants to ensure that OpenCL actually finds those cards. By default OpenCL looks into its own directory for the amdocl64_40000.icd (which is just some file it apparently needs, I thought it was card-dependent due to the 40000 code but it does not look like that). However that file is actually located in the rocm folder when using this procedure so change the path of that amdocl64_40000.icd file with:
sudo nano /etc/OpenCL/vendors/amdocl64_40000.icd
and change:
libamdocl64.so
to:
/opt/rocm/opencl/lib/libamdocl64.so
Now you shouldn't get the Failed to list OpenCL platforms error anymore. Source for this last step.
Note
The script was ran on a fresh Ubuntu 20.04 installation. The above instructions did not work after uninstalling the amdgpu-install nor amdgpu-pro-install files. I guess something which also was used by rocm was corrupted during that amdgpu-install process, which I guess did not happen at the fresh Ubuntu 20.04 installation.
a.t.
  • 387
