Now when I switch on the computer, only black screen with the following message shows up:
"Could not write byte: broken pipe" ..... Starting network connection Stopping network connection (the above phrases repeat many times)
Also something like:
Stopping System V runlevel
I cannot type on the screen. It doesn't proceed onto anything. Just hanging there.
Please help! If there's anything I can do to enter and get my files.
Thank you!
HTsoi
It happened to me also. I'm not sure what was the source of this as I did an upgrade, installed some apps and changed themes and icons. Deleting configuration folders from home folder solved my problem, so you should give it a try.
  1. Press CTRL+ALT+F1 key combination.
  2. Log in using TTY.
  3. Delete those folders: .config, .cache, .dbus, .gfvs, .local with rm -R command.
Example:
rm -R /home/user/.config
I'm not sure if all listed folders should be deleted, so you can try one by one. If it solve your problem and you'll able to log in, be prepared for tons of Apport windows ;)
sowizz
I had the sam problem which is caused by an error in var/lib/dpkg/status from a third party package. In this file the status of the update is saved and if there is an error somewhere the following packages are not installed.
Please follow the following steps which helped me (original source: http://forum.ubuntuusers.de/topic/dpkg-configure-a-schlaegt-fehl/ ) :
  • boot normally, not recovery mode and click Str+Alt+F1 to start the terminal input.
  • log in with your password and username
  • type: sudo apt-get -f install
  • you will get a message saying that there is an error in var/lib/dpkg/status and a line where the error is located.
  • use the nano editor (sudo nano -w) to find the package around the line named in the error message and delete the package which causes the problem (more than one line). be careful and only delete the package which causes the problem!
  • likewise delete the same package from the file /var/lib/dpkg/available -run sudo apt-get -f install again and it will run through this time.
this solution is from http://forum.ubuntuusers.de/topic/dpkg-configure-a-schlaegt-fehl/
Malte
