I am setting up a python3 virtual environment for my development, so I am staying away from the package manager apt-install
$ python3 -m venv . # create my environment in my working directory
I then activated the venv and installed pyqt5
$ source bin/activate
$ pip install PyQt5
I am notified of a successful installation and PyQt5 and PyQt5-Sip shows up in my pip list
When I build a sample application I receive the error:
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "/path/to/venv/lib/python3.8/site-packages/PyQt5/Qt/plugins" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, webgl, xcb.
Aborted (core dumped)
I exported the environment variable for debugging
export QT_DEBUG_PLUGINS=1
I try running my application again and here is the specific error I get in the linker
QFactoryLoader::QFactoryLoader() looking at "/path/to/venv/lib/python3.8/site-packages/PyQt5/Qt/plugins/platforms/libqxcb.so"
Found metadata in lib /path/to/venv/lib/python3.8/site-packages/PyQt5/Qt/plugins/platforms/libqxcb.so, metadata=
    "IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
    "MetaData": {
        "Keys": [
            "xcb"
    "archreq": 0,
    "className": "QXcbIntegrationPlugin",
    "debug": false,
    "version": 331520
Got keys from plugin meta data ("xcb") QFactoryLoader::QFactoryLoader() checking directory path "/usr/bin/platforms" ... Cannot load library /path/to/venv/lib/python3.8/site-packages/PyQt5/Qt/plugins/platforms/libqxcb.so: (libxcb-xinerama.so.0: cannot open shared object file: No such file or directory)
The important error here is
So I dig deeper. I decide to use the ldd command to parse the shared library dependencies.
$ ldd /path/to/venv/lib/python3.8/site-packages/PyQt5/Qt/plugins/platforms/libqxcb.so
and lo-and behold:
libxcb-xinerama.so.0 => not found
These shared libraries are missing from the libqxcb shared library dependencies list. I would hope pip's installation would have this included but it is not. I have not found a solution to this problem anywhere, and the small amount of sources I have found mentioned using apt-install to solve these issues. I don't want to change my system, I prefer keeping things sandboxed.
What can I do to fix this dependency?
Asicc
  • 51
The exact same issue occurred when I installed pyqt5 and matplotlib on Ubuntu 20.04, using pipenv (which also creates a venv).
On my system this was easily solved by installing the missing libxcb-xinerama0, using apt:
sudo apt install libxcb-xinerama0
djvg
  • 386
I'm on Ubuntu 18.04.3 and encountered the same issue. Here is what I resolved this problem.
Uninstall PyQt by using pip3
pip3 uninstall pyqt5
And install it via apt-get
sudo apt-get install python3-pyqt5
Nga Nga
I didn't find them with pip either. I think you're stuck either compiling this from source (https://xorg.freedesktop.org/archive/individual/lib/libxcb-1.14.tar.xz) and linking to it, or installing libxcb-xinerama0.
ajgringo619
  • 1,243
