Whenever I run a command :
updatedb
I get the message :
File size limit exceeded (core dumped)
Why is that ?
I know that locate command utilizes a database created by a related utility, updatedb. Most Linux systems run this automatically once a day. However, you can update it at any time by just running updatedb from the command line as the root user.
update :
root@node1:~# ulimit -a
core file size (blocks, -c) 0 data seg size (kbytes, -d) unlimited scheduling priority (-e) 0 file size (blocks, -f) 2001 pending signals (-i) 23227 max locked memory (kbytes, -l) 65536 max memory size (kbytes, -m) unlimited open files (-n) 1024 pipe size (512 bytes, -p) 8 POSIX message queues (bytes, -q) 819200 real-time priority (-r) 0 stack size (kbytes, -s) 8192 cpu time (seconds, -t) unlimited max user processes (-u) 23227 virtual memory (kbytes, -v) unlimited file locks (-x) unlimited
Tomas.R
  • 433
Your file size is limited to 2001 blocks.
As per this tutorial increase it using:
vi /etc/security/limits.conf
By comparison my system which is stock has:
$ ulimit -a
file size               (blocks, -f) unlimited
pending signals                 (-i) 127556
max locked memory       (kbytes, -l) 64
max user processes              (-u) 127556
