After upgrading my Lenovo ubuntu 16.04 --> 18.04 --> 20.04, most annoying issue is the booting time almost (2 min ~ 2 min 20 sec) starting by clicking the power on, till it is fully ready to be used, on the following manner:
  • Till the Ubuntu logo and loading sign shows up: around 45 seconds!!
  • Since logo and loading till the login box: around 50 seconds
  • After login till desktop shows up: around 20 seconds
I know this is a very common issue on 20.04, but all solutions i found either doesn't match my case or didn't work with me specially deactivate unnecessary services, swap partition UUID double check ..etc.
I can't install it from scratch due to the installed environment and data i have, that it is very hard and a lot of time to re-configure and re-install again.
root@Lenovo-G580:~# systemd-analyze
Startup finished in 5.929s (kernel) + 1min 6.508s (userspace) = 1min 12.438s
graphical.target reached after 1min 5.880s in userspace
root@Lenovo-G580:~# systemd-analyze blame 29.707s plymouth-quit-wait.service
19.960s dev-sda1.device
18.337s systemd-journal-flush.service
14.221s udisks2.service
13.322s networkd-dispatcher.service
12.024s accounts-daemon.service
8.895s dev-loop2.device
8.710s dev-loop1.device
8.707s dev-loop3.device
8.684s avahi-daemon.service
8.493s dev-loop4.device
8.439s polkit.service
8.420s dev-loop0.device
8.327s NetworkManager.service
8.150s switcheroo-control.service
8.131s thermald.service
8.129s systemd-logind.service
8.126s wpa_supplicant.service
7.004s systemd-udevd.service
5.232s ModemManager.service
4.695s apport.service
4.685s gpu-manager.service
4.582s grub-common.service
4.015s e2scrub_reap.service
3.856s rsyslog.service
3.463s apparmor.service
3.270s ssh.service
1.959s networking.service
1.696s lm-sensors.service
1.674s grub-initrd-fallback.service
1.519s systemd-tmpfiles-setup.service
1.416s keyboard-setup.service
1.411s apache-htcacheclean.service
1.342s systemd-modules-load.service
1.309s snapd.apparmor.service
1.300s systemd-resolved.service
1.102s systemd-sysusers.service
root@Lenovo-G580:~# systemd-analyze critical-chain The time when unit became active or started is printed after the "@" character. The time the unit took to start is printed after the "+" character.
graphical.target @1min 5.880s └─multi-user.target @1min 5.880s └─ModemManager.service @35.995s +5.232s └─polkit.service @27.542s +8.439s └─basic.target @26.902s └─sockets.target @26.902s └─uuidd.socket @26.902s └─sysinit.target @26.756s └─systemd-timesyncd.service @26.303s +452ms └─systemd-tmpfiles-setup.service @24.738s +1.519s └─systemd-journal-flush.service @6.400s +18.337s └─systemd-remount-fs.service @5.992s +173ms └─systemd-journald.socket @5.627s └─-.mount @5.624s └─system.slice @5.624s └─-.slice @5.624s
My HW specs:
RAM: 8 GB
CPU: Intel(R) Core(TM) i3-3120M CPU @ 2.50GHz
Help please?
Look at your name services switch file and make sure your network settings are correct. You may have a setting that is timing out.
Name service switch (/etc/nsswitch.conf), may be set differently.
Other things to check (network, subnet mask, default router) in network settings. I dont know what 'Modem Manager' is that looks like it is pulling 35 seconds, perhaps it should be disabled instead of timing out, but I dont know your configuration.
Slowness is sometimes hard to troubleshoot, but name service switch and /etc/hosts are used for lookups, so if you are experiencing time outs, that might be an area to start looking.
