I tried several ways to install openjdk and here is what I get when I do: java -version
openjdk version "11.0.4" 2019-07-16
OpenJDK Runtime Environment (build 11.0.4+11-post-Ubuntu-1ubuntu218.04.3)
OpenJDK 64-Bit Server VM (build 11.0.4+11-post-Ubuntu-1ubuntu218.04.3, mixed mode, sharing)
But when I do javac -version, it says javac cannot be found. I do the following: sudo apt-get install default-jre
default-jre : Depends: default-jre-headless (= 2:1.10-63ubuntu1~02) but 2:1.11-68ubuntu1~18.04.1 is to be installed
Depends: openjdk-11-jre but it is not going to be installed
Then: sudo apt-get install default-jdk
default-jdk : Depends: default-jre (= 2:1.10-63ubuntu1~02) but it is not going to be installed
Depends: default-jdk-headless (= 2:1.10-63ubuntu1~02) but it is not going to be installed
Depends: openjdk-11-jdk but it is not going to be installed
Then: sudo update-alternatives --config java
There are 2 choices for the alternative java (providing /usr/bin/java).
Selection Path Priority Status
* 0 /usr/lib/jvm/java-11-openjdk-amd64/bin/java 1111 auto mode
1 /usr/lib/jvm/java-11-openjdk-amd64/bin/java 1111 manual mode
2 /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java 1081 manual mode
How do I fix these issues and have a proper installation of java and javac?
