I had a dual boot setup with Win10 & 20.04 working well on a SSD. I hadn't booted into Win10 in 5 months, and was pretty sure the Winupdate was going to blow away my multiboot as it had on other PCs. So reading forums like this one, said the best way to protect my Linux installation was to have Ubuntu on a separate drive.
So got an NVMe drive for Cyber Monday, want to use that as my primary Win10 drive. Then want to multiboot between the new Windows installation on the NVMe and the original 20.04 installation on the SSD. The old Win10 install on the SSD is still intact, but will reformat that for additional Win10 space.
In theory, my thought was to create another dual boot installation on the NVMe, installing a fresh 20.04 installation on some space on the NVMe, then repoint grub details / UUID to the old installation (and ultimately delete the “new” installation thereafter).
  1. Would that work?
  2. Is that the best way?
Appreciate any insight taking the theory into pragmatic steps to make it work. Thank you.
Used oldfred's post:
Went into my PCs UEFI and directly booted into my prior Ubuntu installation. Opened a command line, ran sudo update-grub which added the new Windows NVMe install to the boot menu. Then setup the UEFI to have my grub bootloader / ubuntu as my default boot priority. Now will use efibootmgr to clean up the prior install. Very quick and elegant, and will avoid issues if Win10 blows away any bootmgr priority in the future.
Cheers oldfred. I need to find out how to give you credit!
