Upgraded my SSD. Installed Ubuntu 18.04 LTS. Need help in finding or creating Windows 10 bootloader/efi info.
This was my previous config:
My Laptop had both SSD and HDD.
On SSD (250GB):
|__Ubuntu 16.04 +
|__Bootloader (GRUB?) - shows both Ubuntu and Windows
On HDD (1TB): |__Windows 10 (separate partition) + |__all my files/code/projects (on a separate partition).
Grub menu showed option to boot from either Ubuntu or Windows.
My Current config:
  • I now upgraded my SSD. Replaced the old one with a new 1TB SSD.
  • I installed Ubuntu 18.04 on the new SSD. No issues here.
  • Grub menu shows only Ubuntu, as expected.
  • Windows 10 OS is still on HDD.
  • Now, I just need to either find the existing Windows 10 bootloader or create a new one.
On SSD (1TB): (new one)
|__Ubuntu 18.04 +
|__Bootloader (GRUB?) - shows only Ubuntu
On HDD (1TB): (no change) |__Windows 10 (separate partition) + |__all my files/code/projects (on a separate partition).
I tried boot-repair on Ubuntu, and got the suggestions shown on this pastebin link.
I am worried about my files/code/projects which are on HDD. Dont want to loose them at any cost.
How do I safely enable booting into Windows 10 along with Ubuntu?
Few Queries:
I have few doubts:
1. This is the part of the output from pastebin efibootmgr -v cmd:
Boot0000* Windows Boot Manager  HD(1,GPT,878eab28-346d-48ff-bcfb-75f03235beee,0x800,0xfa000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}....................
Boot0001* ubuntu    HD(1,GPT,d7ec3e6a-5b15-4e8e-9019-d424bb0cabe7,0x800,0x76800)/File(\EFI\ubuntu\shimx64.efi)
Looks like it seems to have found Windows boot manager and that it is in EFI mode (not Legacy).
But under Drive/Partition Info section, it shows that sda is notGPT. Seem to contradict the above info. What am I missing?
nvme0n1 : is-GPT,   no-BIOSboot,    has---ESP,  not-usb,    not-mmc, has-os,    2048 sectors * 512 bytes
sda : notGPT,   no-BIOSboot,    has-noESP,  not-usb,    not-mmc, has-os,    2048 sectors * 512 bytes
It also seems to have found OSs in nvme0n1p3 (Ubuntu) and sda1 (Win).
nvme0n1p3   : is-os,    64, apt-get,    signed grub-pc grub-efi ,   grub2,  grub-install,   grubenv-ok, update-grub,    farbios
sda1    : is-os,    32, nopakmgr,   no-docgrub, nogrub, nogrubinstall,  no-grubenv, noupdategrub,   farbios
Under Suggested Repair I see:
The default repair of the Boot-Repair utility would purge (in order to remove grub-efi) and reinstall the grub2 of
nvme0n1p3 into the MBRs of all disks (except live-disks and removable disks without OS).
Can I go with this recommeded defaults?
3. It also says: "Grub-efi would not be selected by default because: legacy-win no-win-efi".
  • Does this mean Windows 10 was loaded in Legacy mode and not UEFI mode?
  • Or is it just that it didn't find the Windows EFI?
It also suggests "Please enable BIOS-compatibility/CSM/Legacy mode in your UEFI firmware". Instead can I just convert Windows 10 to UEFI model from Legacy using mbr2gtp? But will I risk loosing all my files on HDD by doing this?
5. Didnt quite understand, what happens if I select this option: "Alternatively, you can retry after activating the [Separate /boot/efi partition:] option"
I guess most of the other info can be found on this link. Please let me know if you need any other info.
I would like to emphasize that not loosing my files on HDD is of higher importance than getting back my Win 10 install.
Also, would a fresh install of Windows make things easier instead of repairing my boot?
Additional Notes:
  • I tried startup repair using Windows Recovery USB, but didnt work.
  • os-prober on Ubuntu didnt return anything.
  • update-grub didnt fix it.
  • I got to know that I cannot mix Legacy boot option and EFI boot (https://help.ubuntu.com/community/UEFI). But I dont know if my Windows is on Legacy(MBR) or GPT.
  • Rechecked my BIOS - it is on UEFI and Legacy is not enabled. It was like this from before and I didnt change it now.
  • Secure boot is disabled.
Appreciate any help.
