I cannot access settings. When I do, my laptop freezes. The mouse still moves, but it is a spinner that doesn't stop spinning.
This is the latest issue I've encountered as I try to install Linux on a machine with Windows preinstalled.
I installed Ubuntu 20.10 on 2 days ago. After having to perform software updates, everything seemed good and stable. The only problem I encountered was that the machine would not shut down. Ubuntu would shut down and close, but then a system screen showed with a bunch of text. As far as I could understand, the system was having trouble ending all the processes.
Last night, I went to shut down my machine, and did not force a shut down just to see what would happen. I went home for the night (this is a work machine), and this morning, the machine was still on, seemingly stuck in some infinite loop of trying to shut down processes and failing, then trying again.
I forced another shutdown then started the machine again. I continued by trying to get work done. I then noticed my second display (HDMI) would start freezing. The display would freeze, turn off, then come back, but be unresponsive. In other words, the display showed all my windows open like normal, but everything was unresponsive. Everything in my main display continued behaving normally. If I checked display settings, it would recognize the second display. I decided to set the screen to a single display, then flip it back to dual. When I did that, everything froze.
Now, after restart, if I attempt to access any Settings, the system just spins and spins. I've diconnected my hdmi port. I can use the machine like normally, but I cannot access Settings, or use dual displays.
Any ideas on how to troubleshoot? Should I just give up on having Linux on this machine? Seems there are lots of bugs related to AMD graphics and Linux.
