I recently install Anbox on my Ubuntu 20.04. I found on the post Module "ashmem" doesn't load with Secure Boot on (but "binder" does load with secure boot on) that I need to load ashmem and binder. Loading binder is fine but I fail to load ahsmem. Therefore, as suggested in the aforementioned post, I tried to run:
sudo kmodsign sha512 /var/lib/shim-signed/mok/MOK.priv /var/lib/shim-signed/mok/MOK.der /lib/modules/`uname -r`/kernel/drivers/staging/android/ashmem_linux.ko
But in my case, this command raises the following error:
At main.c:248:
- SSL error:02001002:system library:fopen:No such file or directory: ../crypto/bio/bss_file.c:69
- SSL error:2006D080:BIO routines:BIO_new_file:no such file: ../crypto/bio/bss_file.c:76 kmodsign: /var/lib/shim-signed/mok/MOK.priv: No such file or directory
Could anyone please help me here ?
Lucas
EDIT
I found on the page https://wiki.ubuntu.com/UEFI/SecureBoot, the command:
sudo update-secureboot-policy --new-key
I can now run
without any error but sudo modprobe ashmem_linux still raises
modprobe: ERROR: could not insert 'ashmem_linux': Operation not permitted
