Below is the last screen output up to the failure:
Distro set to: Ubuntu 16.04
Initializing. Please wait...
SECURITY PACKAGES
AppArmor is installed. AppArmor protects the application from external intrusion attempts making the application secure
Would you like to have this installer install the hplip specific policy/profile (y=yes*, n=no, q=quit) ? y
RUNNING PRE-INSTALL COMMANDS
OK
RUNNING HPLIP LIBS REMOVE COMMANDS
None OK
RUNNING SCANJET DEPENDENCY COMMANDS
sudo apt-get install --assume-yes python-pip (Scanjet-depend step 1) sudo pip install --upgrade pip (Scanjet-depend step 2) sudo apt-get install --assume-yes libleptonica-dev (Scanjet-depend step 3) sudo apt-get install --assume-yes tesseract-ocr (Scanjet-depend step 4) sudo apt-get install --assume-yes libtesseract-dev (Scanjet-depend step 5) sudo -H pip install tesserocr (Scanjet-depend step 6) sudo apt-get install --assume-yes libzbar-dev (Scanjet-depend step 7) sudo apt-get install --assume-yes python-zbar (Scanjet-depend step 8) sudo apt-get install --assume-yes python-opencv (Scanjet-depend step 9) sudo apt-get install --assume-yes python-pypdf2 (Scanjet-depend step 10) sudo -H pip install imutils (Scanjet-depend step 11) sudo -H pip install pypdfocr (Scanjet-depend step 12) sudo -H pip install scikit-image (Scanjet-depend step 13) sudo -H pip install scipy (Scanjet-depend step 14) OK
PRE-BUILD COMMANDS
OK
BUILD AND INSTALL
Running './configure --with-hpppddir=/usr/share/ppd/HP --libdir=/usr/lib --prefix=/usr --enable-qt4 --disable-qt5 --enable-doc-build --disable-cups-ppd-install --disable-foomatic-drv-install --disable-libusb01_build --disable-foomatic-ppd-install --disable-hpijs-install --disable-class-driver --disable-udev_sysfs_rules --disable-policykit --enable-cups-drv-install --enable-hpcups-install --enable-network-build --enable-dbus-build --enable-scan-build --enable-fax-build --enable-apparmor_build' Please wait, this may take several minutes... Command completed successfully.
Running 'make clean' Please wait, this may take several minutes... Command completed successfully.
Running 'make' Please wait, this may take several minutes... error: 'make' command failed with status code 2
Nmath
  • 12,664
