Built a new PC: 10700k, z490 MSI board, 32gb Ram etc. Running Ubuntu 20.04 and getting an MCE (Machine Check Error): kernel: [ 0.185888] mce: CPU0: Thermal monitoring enabled (TM1).
The PC is just running the Game boost from the MSI Bios, and not manually overclocked. Using a Corsair H115 2*140mm cooler, with temperatures on idle being at most 32 degrees per core.
Apart from getting these MCE errors, sometimes the PC completely freezes when left on idle. A force restart is the only option. What could this be?
memtest
Go to https://www.memtest86.com/ and download/run their free memtest to test your memory. Get at least one complete pass of all the 4/4 tests to confirm good memory. This may take many hours to complete.
BIOS
MSI-Z490 Gaming Edge Wifi
You have BIOS version 1.00.
There's a newer BIOS available that might help solve your problem, version 1.30, dated 10/14/2020, and can be downloaded here.
Note: Confirm that I have the correct web page for your motherboard model #.
Note: Have good backups before updating the BIOS.
/swapfile
Even though you have a lot of memory, a swap partition or /swapfile is still recommended. Let's create a fresh /swapfile...
Note: Incorrect use of the dd command can cause data loss. Suggest copy/paste.
In the terminal...
sudo swapoff -a           # turn off swap
sudo rm -i /swapfile      # remove old /swapfile
sudo dd if=/dev/zero of=/swapfile bs=1M count=4096
sudo chmod 600 /swapfile # set proper file protections sudo mkswap /swapfile # init /swapfile sudo swapon /swapfile # turn on swap free -h # confirm 32G RAM and 4G swap
Confirm this /swapfile line at the end of /etc/fstab... and confirm no other “swap” lines...
To edit, use sudo -H gedit /etc/fstab or sudo pico /etc/fstab
/swapfile  none  swap  sw  0  0
reboot                    # reboot and verify operation
vm.swappiness
Since you have 32G RAM, to minimize swapping, let's change this value...
Set vm.swappiness=10 (based on 32G RAM and 4G SWAP), this way...
sudo -H gedit /etc/sysctl.conf # edit this file
Search for an existing vm.swappiness= entry...
CTRL+f vm.swappiness
  • If found, edit it to say vm.swappiness=10
  • If not found, add vm.swappiness=10 at the end of the file
Save your edits and quit gedit
sudo sysctl -p
Update #1:
Set intel_idle.max_cstate=1 in /etc/default/grub, and then sudo update-grub and reboot solved the problem.
heynnema
  • 73,649
