My default keyboard layout is Norwegian (from the 12.04 installation procedure). But I also want to use Icelandic.
Two layouts in the "system settings" → "keyboard layouts" is one too many. I cannot switch either using a shortcut or in the Panel.
The Panel tells me I have switched, but the letters I type are Norwegian, even when the Panel seems to have switched to Icelandic.
My language for menus and windows ("system settings" → "language support") is English. "Regional formats" → "Display numbers, dates ….": English Denmark,
What am I doing wrong?
guntbert
  • 13,475
kle
  • 109
Maybe you can try this:
sudo setxkbmap -option grp:alt_shift_toggle no,ru
This maybe can help you but you have to do it everytime you log in to your system. You can add this command to execute
ashutosh
  • 1,302
OP-provided answer, probably inspired by @ashutosh
To enable toggling between two keyboards for current session:
  sudo setxkbmap -option grp:alt_shift_toggle no,is
To permanently set several keyboards (Norwegian, Icelandic, Spanish)
  sudo gedit /etc/default/keyboard
Edit line 2 thus:
  XKBMODEL="pc105"
  XKBLAYOUT="no, is, es"
  XKBVARIANT=""
  XKBOPTIONS=""
guntbert
  • 13,475
go keyboard settings -> options and from the popup click the arrow at Key(s) to change layout and select the shortcut you need
themhz
  • 477
Add (and install) the layout it is using but move the wanted layout to top on the keyboard layouts list (System settings -> Keyboard Layout -> Layouts). Reboot. Logout. Login checking that the wanted layout is selected in the login screen. Reboot and test if working.
IJK
  • 26
