I am new to Ubuntu and I am trying to get a Mercusys AC650 usb wifi to work in Ubuntu 20.04. I was very happy to see a solution already listed here in Ask Ubuntu and I followed some commands which had the AC650 connecting to my wifi. The commands from the question 'Realtek RTL8811CU Wifi Dongle' that I used to have the wifi working initially were;
sudo apt install build-essential -y
mkdir -p ~/build
cd ~/build
sudo apt install git
git clone https://github.com/brektrou/rtl8821CU.git
cd rtl8821CU
make
sudo make install
However the wifi stopped functioning and I had to get a wired connection up to get the internet once more. Once back on the internet I moved the folder ~/build/rtl8821CU to the recycling folder and completed the commands listed above to once again have the wifi working once more. I think the first time the wifi stopped working was due to a ubuntu software update having been completed and then a reboot of the machine. When the software update initialised once again after the wifi was once more working for a second time the wifi stopped working after I rebooted.
Please could you advise how I get this Mercusys AC650 wifi working once more in Ubuntu 20.04 as I believe the automatic software updates cause the code I used previously to good effect to now no longer function?
Peter
You can use dkms to install the driver for a new kernel version, in terminal do
cd rtl8821CU
make clean
sudo ./dkms-install.sh
Jeremy31
  • 13,293
Try installing this: https://github.com/morrownr/8821cu-20210118
First update and upgrade system packages:
sudo apt update && sudo apt upgrade
Then install all the required packages:
sudo apt install -y build-essential dkms git
Then download te driver in a folder and remove all the previous drivers.
mkdir ~/build
cd ~/build
git clone https://github.com/morrownr/8821cu-20210118
cd 8821cu-20210118
git pull
sudo ./remove-driver.sh
At this point you will need to reboot. Afetr rebooting:
cd ~/build/8821cu-20210118
sudo ./install-driver.sh
And accept to reboot when offered.
Hope it helps, I've been trying different drivers for a week now and this was the only one that worked.
Best regards.
P.M.
