grub-install fails to reinstall grub with:
Installing for x86_64-efi platform.
grub-install: warning: Internal error.
grub-install: error: failed to register the EFI boot entry: Operation not permitted.
I noticed while performing an upgrade which tries to upgrade the package grub-efi-amd64-signed. This gives a more informative error message:
Installing grub to /boot/efi.
mount: /var/lib/grub/esp: mount point does not exist.
The system is trying to find the EFI partition on /var/lib/grub/esp
This is strange since my fstab looks correct,
/dev/sda7 has the boot flag and /dev/sda2 has the esp flag. I don't know why grub-install goes to /var/lib to try to find the efi partition. The error still persists even if I explicitly pass the directories to grub-install.
grub-install --efi-directory=/boot/efi/ --boot-directory=/boot/
I tried running boot repair, but it did not fix the problem.
pip1726
  • 171
Same error on 18.04.6 LTS (GNU/Linux 4.15.0-147-generic x86_64)
My solution was to replace --auto-nvram with --no-nvram where grub-install is called (as suggested here and here).
vim /var/lib/dpkg/info/grub-efi-amd64-signed.postinst
vim /var/lib/dpkg/info/shim-signed.postinst
Then run apt upgrade again with no errors.
hrvoj3e
  • 181
After turning off Fast Boot UEFI settings, the grub-install problem vanished. I also turned off Fast Boot from withing Windows itself as advised by @oldfred. grub-install works. However, when I upgrade the grub-efi-amd64-signed package, I still get the same /var/lib/grub/esp error:
Setting up grub-efi-amd64-signed (1.142.9+2.04-1ubuntu26.7) ...
Installation finished. No error reported.
dpkg: error processing package grub-efi-amd64-signed (--configure):
 installed grub-efi-amd64-signed package post-installation script subprocess returned error exit status 32
After that, purging grub and reinstalling grub by running the following commands solved the grub-efi-amd64-signed installation issue.
sudo apt-get purge grub\*
sudo apt-get install grub-efi
sudo apt-get autoremove
sudo update-grub
pip1726
  • 171
