Apologies if this has been beaten to death. I've done about 6 hours of searching and testing myself and pulling my hair out.
After a backup, I reluctantly agreed to upgrade from 18.04 to 20.04. Aside from having to fix a few custom packages, things were generally OK.
First issue was a lack of DNS. I honestly can't remember now how I fixed it. However, I think it's related to my main issue.
I run this host in a static IP configuration. However, upon upgrade, I see a secondary address via DHCP on the ethernet interface (enp0s3). No matter what I do, I can't seem to shake it.
Even more odd: Within Gnome (which I've always avoided before), if I delete that connection (called enp0s3), it just comes back on its own. "Wired Connection 1" is my static interface.
Another possible clue, even if I slide the slider to disable the network connection, it just slides back over to enabled/green on its own within a few seconds.
I'm wondering if I'm getting conflicts between NetworkManager, Netplan, or Networkd
Thanks for any insight.
sudo lshw -C network
*-network
description: Ethernet interface
product: 82540EM Gigabit Ethernet Controller
vendor: Intel Corporation
physical id: 3
bus info: pci@0000:00:03.0
logical name: enp0s3
version: 02
serial: 08:00:27:ab:a2:8f
capacity: 1Gbit/s
width: 32 bits
clock: 66MHz
capabilities: pm pcix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000 driverversion=7.3.21-k8-NAPI duplex=full ip=192.168.34.25 latency=64 link=yes mingnt=255 multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:9 memory:f0000000-f001ffff ioport:d010(size=8)
cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
cat /etc/netplan/*.yaml
# Let NetworkManager manage all devices on this system
network:
version: 2
renderer: NetworkManager
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp0s3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 08:00:27:ab:a2:8f brd ff:ff:ff:ff:ff:ff
inet 192.168.34.25/24 brd 192.168.34.255 scope global noprefixroute enp0s3
inet 192.168.34.12/24 brd 192.168.34.255 scope global secondary noprefixroute enp0s3
inet6 fe80::80e1:7fc:b61a:cd41/64 scope link noprefixroute
root@homeauto03:/etc/NetworkManager/system-connections# ls -altr
total 12
drwxr-xr-x 7 root root 4096 Nov 30 21:09 ..
-rw------- 1 root root 393 Dec 1 13:47 'Wired connection 1.nmconnection'
drwxr-xr-x 2 root root 4096 Dec 1 16:24 .
root@homeauto03:/etc/NetworkManager/system-connections# cat Wired\ connection\ 1.nmconnection
[connection]
id=Wired connection 1
uuid=358648bf-1c3e-3704-995a-300a184d0445
type=ethernet
autoconnect-priority=-999
interface-name=enp0s3
permissions=
timestamp=1606848238
[ethernet]
mac-address-blacklist=
[ipv4]
address1=192.168.34.12/24,192.168.34.1
dns=8.8.8.8;8.8.4.4;
dns-search=
ignore-auto-dns=true
method=manual
[ipv6]
addr-gen-mode=stable-privacy
dns-search=
method=auto
[proxy]
tbully@homeauto03:~$ ip a
inet 192.168.34.12/24 brd 192.168.34.255 scope global noprefixroute enp0s3
inet 192.168.34.25/24 brd 192.168.34.255 scope global secondary noprefixroute enp0s3
TEMPORARY SOLUTION
- executed
systemctl stop dhcpcd.service - removed connection profile in
NetworkManager - noted that both pings stopped working - .12 (static) and .25 (dhcp) assigned
- also noted that the enable button didn't go back to green on its own (and connection being re-enabled) did not occur as it did before
- recreated the manual ipv4 connection (.12).
- pings started back up for .12
- noted that .25 (or any other dhcp address) did not reassign
- excuted
systemctl disable dhcpcd.service - survived
reboot
Reveresed these steps (re-enabled the DHCP client) and the problem returned.
Nuke option but it'll work for now until I (or someone) can figure out a more proper solution.
