For ANY Makefile, do a cat Makefile and look at the very end of the listing. There you'll find what options make will understand (for that particular Makefile).
Look at the following code snippet... and look for "option:"... and in this example, we can see "all:" and "modules:" and etc... all the way down to "uninstall:"... and even a few more after that.
This typically means (in this case example), following your initial make command, and sudo make install to build and install the code, you can use sudo make uninstall to remove the installed code.
all: modules
modules:
$(MAKE) ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE) -C $(KSRC) M=$(shell pwd) modules
@echo "---------------------------------------------------------------------------"
@echo "Visit https://github.com/aircrack-ng/rtl8812au for support/reporting issues"
@echo "or check for newer versions (branches) of these drivers. "
strip:
$(CROSS_COMPILE)strip $(MODULE_NAME).ko --strip-unneeded
install:
install -p -m 644 $(MODULE_NAME).ko $(MODDESTDIR)
/sbin/depmod -a ${KVER}
uninstall:
rm -f $(MODDESTDIR)/$(MODULE_NAME).ko
backup_rtlwifi:
@echo "Making backup rtlwifi drivers"
ifneq (,$(wildcard $(STAGINGMODDIR)/rtl))
@tar cPf $(wildcard $(STAGINGMODDIR))/backup_rtlwifi_driver.tar $(wildcard $(STAGINGMODDIR)/rtl)
@rm -rf $(wildcard $(STAGINGMODDIR)/rtl)
endif
ifneq (,$(wildcard $(MODDESTDIR)realtek))
@tar cPf $(MODDESTDIR)backup_rtlwifi_driver.tar $(MODDESTDIR)realtek
@rm -fr $(MODDESTDIR)realtek
endif
ifneq (,$(wildcard $(MODDESTDIR)rtl))
@tar cPf $(MODDESTDIR)../backup_rtlwifi_driver.tar $(wildcard $(MODDESTDIR)rtl)
@rm -fr $(wildcard $(MODDESTDIR)rtl)
endif
@/sbin/depmod -a ${KVER}
@echo "Please reboot your system"
restore_rtlwifi:
@echo "Restoring backups"
ifneq (,$(wildcard $(STAGINGMODDIR)/backup_rtlwifi_driver.tar))
@tar xPf $(STAGINGMODDIR)/backup_rtlwifi_driver.tar
@rm $(STAGINGMODDIR)/backup_rtlwifi_driver.tar
endif
ifneq (,$(wildcard $(MODDESTDIR)backup_rtlwifi_driver.tar))
@tar xPf $(MODDESTDIR)backup_rtlwifi_driver.tar
@rm $(MODDESTDIR)backup_rtlwifi_driver.tar
endif
ifneq (,$(wildcard $(MODDESTDIR)../backup_rtlwifi_driver.tar))
@tar xPf $(MODDESTDIR)../backup_rtlwifi_driver.tar
@rm $(MODDESTDIR)../backup_rtlwifi_driver.tar
endif
config_r:
@echo "make config"
/bin/bash script/Configure script/config.in
DRIVER_VERSION = $(shell grep "#define DRIVERVERSION" include/rtw_version.h | awk '{print $$3}' | tr -d v")
dkms_install:
mkdir -p /usr/src/8812au-$(DRIVER_VERSION)
cp -r * /usr/src/8812au-$(DRIVER_VERSION)
dkms add -m 8812au -v $(DRIVER_VERSION)
dkms build -m 8812au -v $(DRIVER_VERSION)
dkms install -m 8812au -v $(DRIVER_VERSION)
dkms status
dkms_remove:
dkms remove 8812au/$(DRIVER_VERSION) --all
rm -rf /usr/src/8812au-$(DRIVER_VERSION)
.PHONY: modules clean
clean:
#$(MAKE) -C $(KSRC) M=$(shell pwd) clean
cd hal ; rm -fr ///.mod.c ///.mod ///.o ///..cmd ///.ko
cd hal ; rm -fr //.mod.c //.mod //.o //..cmd //.ko
cd hal ; rm -fr /.mod.c /.mod /.o /..cmd /.ko
cd hal ; rm -fr .mod.c .mod .o ..cmd .ko
cd core ; rm -fr /.mod.c /.mod /.o /..cmd /.ko
cd core ; rm -fr .mod.c .mod .o ..cmd .ko
cd os_dep/linux ; rm -fr .mod.c .mod .o ..cmd .ko .o.d
cd os_dep ; rm -fr .mod.c .mod .o ..cmd .ko
cd platform ; rm -fr .mod.c .mod .o ..cmd .ko
rm -fr Module.symvers ; rm -fr Module.markers ; rm -fr modules.order
rm -fr .mod.c .mod .o ..cmd .ko *~
rm -fr .tmp_versions
endif
