I run Ubuntu 18.04 in a VMWare virtual machine. Something has happened that caused there to apparently be an I/O problem. Every time I boot the machine, after only about 1 minute, the entire filesystem /dev/sda1 gets placed into read-only mode, presumably by the kernel.
I've rebooted, and when I reboot, I'm brought to an initramfs prompt, in which I then have tried the advice on How to fix "sudo: unable to open ... Read-only file system"? except for remounting, because I don't want to do this if the kernel has indeed placed it into ro for data integrity protection.
When I run fsck -yf /dev/sda1, it fixes some inode errors and a couple other issues, then I run again, same thing, then finally, no more errors... I continue the boot process, and about 1 or 2 minutes in, the whole filesystem locks again. I can't even insert a drive to copy files to because it cannot mount on a read-only file system. I can't go to websites to upload my files because the browsers won't work on read-only file system, etc...
What I want to do at this point is back up the data, so I'm wondering how I can do this as this is a VMWare VM, it is not on bare-metal. On bare-metal, I'd probably insert a LiveCD and try to boot into it, but am unsure how to do this for VMWare and if there may be an alternate option. The disk is a virtual VMWare disk, and there are no physical problems with my underlying hardware, as my other VMs and host machine are fine.
You can attach an ISO image of the live DVD as a virtual DVD drive to your VM in the vSphere client (or other VMware tool you use to configure VMs) and boot from it. I've done it many times.
raj
  • 11,409
