I am trying to install R4.0 package in the arm64 ubuntu server (focal) on th AWS. I followed the install instruction on this web site, https://rtask.thinkr.fr/installation-of-r-4-0-on-ubuntu-20-04-lts-and-tips-for-spatial-packages/ and worked without a hitch when installing R4.0 on the x86_64 ubuntu server. I tried potential solutions posted on the web but none has worked so far. At this point, I'd really appreciate any pointer to address this issue.
The error I get after firing sudo apt install r-base are as follows;
Reading package lists... Done
Building dependency tree
r-base : Depends: r-base-core (>= 4.0.3-1.2004.0) but it is not going to be installed
Depends: r-recommended (= 4.0.3-1.2004.0) but it is not going to be installed
Recommends: r-base-html but it is not going to be installed
Recommends: r-doc-html but it is not going to be installed
AWS system info
neofetch --stdout
ubuntu@ip-172-31-17-200
OS: Ubuntu 20.04.1 LTS aarch64
Host: a1.metal 1.0
Kernel: 5.4.0-1029-aws
Packages: 797 (dpkg), 5 (snap)
Shell: zsh 5.8
Terminal: /dev/pts/0
CPU: (16)
cat /etc/os-release
NAME="Ubuntu"
ERSION="20.04.1 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.1 LTS"
VERSION_ID="20.04"
