I have a HP computer and installed Ubuntu on it. I followed all the installation procedures as shown on the Ubuntu website. I installed it in order to dual boot into Windows 10. Now, my computer boots directly to Ubuntu. It does not even show the grub menu. I can get to see the grub menu only if I restart the computer while holding the "Windows" and shift key down. When I see the grub menu by using the shift key method, I see the following message when I choose Windows:
error:can't find the command 'drivemap'. error: invalid EFI file path Press any key to continue...
Due to some confusion in the installation instructions, I might have made a small error during the installation of Ubuntu and might have mistakenly created an extra EFI partition.
a) I looking to fix this dual boot issue. b) I am also fine if you can tell me how to delete Ubuntu and go back to using windows. ( I dont have any sort of windows installation CD or USB.
I did this for now: sudo gedit /etc/grub.d/40_custom Then added the following in 40_custom...
#!/bin/sh
exec tail -n +3 $0
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
menuentry "WINDOWS10 (on /dev/sda5)" --class windows --class os {
   insmod part_msdos
   insmod ntfs
   set root='(/dev/sda,msdos1)'
   search --no-floppy --fs-uuid --set=root defca89a-1c4c-4e17-a2wf-  fdp6c15bd69q
   drivemap -s (hd0) ${root}
   chainloader +1
Thank you
Screenshot of my lsblk
I also have dual boot Windows 10 and Ubuntu in my HP (UEFI / EFI) laptop. Are you sure your followed all the ways correctly? Just boot in to your ubuntu and check for disks application. It will show all partitions in your hard-disk. If you see no windows partition drives, then you have lost windows, else while ubuntu boots, press the boot key. In Hp ( f9) to choose where to boot ( like in Ubuntu or windows boot manager). Then select windows boot manager.
Re-installing Ubuntu (from bootable USB) will resolve the issue. But, make sure this time you allow Ubuntu Disk Manager create disks automatically.
Since you chose to create EFI partition,it's likely that the existing Windows boot information is lost. The most easiest solution for you is to get Windows Recovery disk/installation medium and repair the installation. I know you've mentioned no OS medium but that's your best bet for worry free recovery. Also, looking at the screenshot, I don't think it lists any Windows partition but it could be partially true. Just go ahead and download Windows 10 ISO and try recovery.
