-2
arbas18@arbas18-HP-245-G6-Notebook-PC:~$ sudo apt-get install curl
[sudo] password for arbas18:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
 curl : Depends: libcurl4 (= 7.58.0-2ubuntu3.10) but it is not going to be installed
 libpam-systemd : Depends: systemd (= 237-3ubuntu10.3)
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
karel
  • 122,292
  • 133
  • 301
  • 332
I would do what it says in the help(ful) message:
sudo apt --fix-broken install
Then make sure you are up to date:
sudo apt update sudo apt upgrade
And then try installing curl again
