I've got a weird problem with my Ubuntu Ubuntu 20.04.1. Actually release version doesn't matter because the problem was even before release upgrade. During every boot the system does something for 2 minutes. dmesg shows following:
[    3.882138] ata3.00: ATA-10: ST2000DM008-2FR102, 0001, max UDMA/133
[    3.882831] ata3.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    3.933436] ata3.00: configured for UDMA/133
[    3.934299] scsi 2:0:0:0: Direct-Access     ATA      ST2000DM008-2FR1 0001 PQ: 0 ANSI: 5
[    3.935284] sd 2:0:0:0: Attached scsi generic sg1 type 0
[    3.935293] sd 2:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    3.936220] scsi 3:0:0:0: Direct-Access     ATA      ST2000DX002-2DV1 CC41 PQ: 0 ANSI: 5
[    3.936749] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[    3.937663] sd 3:0:0:0: Attached scsi generic sg2 type 0
[    3.937710] sd 3:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    3.937711] sd 3:0:0:0: [sdc] 4096-byte physical blocks
[    3.937719] sd 3:0:0:0: [sdc] Write Protect is off
[    3.937720] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    3.937732] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.938193] sd 2:0:0:0: [sdb] Write Protect is off
[    3.942949] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    3.942960] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.951078]  sdc: sdc1
[    3.951910] sd 3:0:0:0: [sdc] Attached SCSI disk
[    3.991298] sd 2:0:0:0: [sdb] Attached SCSI disk
[    4.013571] random: fast init done
[    4.028472] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    4.028473] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    4.028504] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    4.153986] raid6: sse2x4   gen() 15011 MB/s
[    4.201978] raid6: sse2x4   xor() 10212 MB/s
[    4.249981] raid6: sse2x2   gen() 12737 MB/s
[    4.297979] raid6: sse2x2   xor()  8628 MB/s
[    4.345979] raid6: sse2x1   gen() 10930 MB/s
[    4.393982] raid6: sse2x1   xor()  7474 MB/s
[    4.394456] raid6: using algorithm sse2x4 gen() 15011 MB/s
[    4.394916] raid6: .... xor() 10212 MB/s, rmw enabled
[    4.395369] raid6: using ssse3x2 recovery algorithm
[    4.396664] xor: automatically using best checksumming function   avx
[    4.397942] async_tx: api initialized (async)
[    4.405574] device-mapper: raid: Loading target version 1.14.0
[    4.428421] md/raid1:mdX: active with 2 out of 2 mirrors
[    9.604725] random: crng init done
[    9.605236] random: 8 urandom warning(s) missed due to ratelimiting
[  120.809255] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[  132.661535] systemd[1]: Inserted module 'autofs4'
/etc/fstab output:
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
UUID=5b736f72-d735-45ca-a5db-fd0a4eef2fa7 /               ext4    errors=remount-ro 0       1
UUID=C824-BAB7  /boot/efi       vfat    defaults      0       1
UUID=d986c290-d182-474b-a05b-91b649aea538                                 none            swap    sw              0       0
UUID=942e0b01-4bf8-4dfe-a9ee-5d4a59dcb0ce       /mnt/mirror     ext4    errors=remount-ro,x-systemd.device-timeout=300 01
UUID=f2c269d7-9346-4686-b697-325d44ad1023       /mnt/storage    ext4    errors=remount-ro       0       1
When I look at the monitor during boot I see something regarding checking the root file system. But later on I can't find this entry anywhere in the logs. Also during this 2 minutes pause I hear heavy usage of the HDD although my root file system is located on SDD (I have 2 mirrored HDDs).
What could it be? Not that it's a big problem but annoys a little.
Ralfeus
  • 143
This message is usually the result of something that exhausts the entropy pool on your system. This is typically refilled over time through various actions (such as disk activity, keyboard timings, mouse movements, etc). The simplest solution would be to use something like haveged:
apt-get install haveged
To have this start at boot, use this:
update-rc.d haveged defaults
