I can't install Steam no matter what I try. Dependencieo over dependencies ... you got it. I tried anything I could, and ended up damaging my system. Now it's like new. Here is the link of tutorial I followed: https://linuxconfig.org/how-to-insta...al-fossa-linux
Here is what happens when I execute sudo apt-get install steam:
techguy@techbook:~/steam$ sudo apt-get install steam
Reading package lists... Done
Building dependency tree
The following information may help to resolve the situation: The following packages have unmet dependencies: steam:i386 : Depends: libgl1-mesa-dri:i386 (>= 17.3) but it is not going to be installed or libtxc-dxtn0:i386 but it is not installable Depends: libgl1-mesa-glx:i386 but it is not going to be installed Depends: libudev1:i386 but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I tried reconfiguring and adding repositories and anything I could, but that libgl1-mesa problem is still there.
I have managed to install steam installer (via .deb) but the problem comes when I launch Steam installer. Here is what happens:
Steam needs to install these additional packages:
libgl1-mesa-dri:i386, libgl1:i386, libc6:i386
[sudo] password for techguy:
The following packages have unmet dependencies: libgl1:i386 : Depends: libglx0:i386 (= 1.3.1-1) but it is not going to be installed libgl1-mesa-dri:i386 : Depends: libglapi-mesa:i386 (= 20.0.4-2ubuntu1) but it is not going to be installed E: Unable to correct problems, you have held broken packages. Press return to continue:
Any ideas?
