11
I am trying to install for example mosquitto package with apt then I do
sudo apt-get install mosquitto
and I get an error
 dpkg: error: fgets gave an empty string from '/var/lib/dpkg/triggers/Unincorp'
 E: Sub-process /usr/bin/dpkg returned an error code (2)
I really don't know what can I do to fix it.
Using Ubuntu Release: 20.10
dahan raz
  • 381
Finally found the answer to this problem, all you need to do is
sudo rm /var/lib/dpkg/triggers/Unincorp
sudo touch /var/lib/dpkg/triggers/Unincorp
and then just run
sudo dpkg --configure -a
IDK why this solves the problem but I guess it's because the file was corrupted...
dahan raz
  • 381
