I had a working usb-drive that I could use for a windows and linux pc. Today I tried to look at some saved files, but the only thing that was on the usb-drive was a .iso-file (I don't know what this is) and my usb-drive is referred to as 'DISK CARD', which I didn't do. When I use sudo fdisk -l, I get the following:
Disk /dev/sdb: 1,88 GiB, 1999110144 bytes, 3904512 sectors
Disk model: Mass-Storage
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sdb1 129 3904511 3904383 1,9G 6 FAT16
I can copy a file to it, but when I unmount the usb-drive and plug it back in, the file is vanished.
I already tried the following:
Reformat it using Disks --> error synchronizing after initial wipe: Timed out waiting for object (udisks-error-quark, 0)
Delete the partition using Disks --> it automatically appears back
Reformat using gparted as suggested here --> no error, but is jumps back to as it was before.
Follow the instructions mentioned here --> everything looks the same, but when using
sudo fdisk -l, I get the same output as before.Crying --> Didn't help...
Does anyones has some other suggestions of what I can try?
Kind regards.
