What I did:
sudo apt-add-repository ppa:ansible/ansible ; sudo apt update ; sudo apt install ansible
Error message:
The following packages have unmet dependencies: ansible : Depends: python-paramiko but it is not installable E: Unable to correct problems, you have held broken packages.
Description:
As you see, the problem is with the python-paramiko package. I tried to install the required package but it hasn't solved the problem.
In addition, none of the following related questions solved the problem.
Thanks in advance.
graham
  • 13,061
