The booting process of Ubuntu 20.04 is taking too much time. I would like to know how to improve boot time.
Here is my Hardware Information:
  • RAM - 4GB
  • Disk Type - HDD
  • Disk Space - 1TB
  • Architecture - amd64
  • Processor - Intel(core i3) 7th generation
If there is any other required information, please comment and I will provide it.
output of dmesg:
Output file click to see
systemd-analyze output:
Startup finished in 4.133s (firmware) + 5.169s (loader) + 5.074s (kernel) + 31min 12.092s (userspace) = 31min 26.470s
graphical.target reached after 3min 9.875s in userspace
systemd-anlyze blame output :
30min 36.678s fstrim.service
 2min 19.796s plymouth-quit-wait.service
      33.670s snapd.service
      31.615s networkd-dispatcher.service
      28.168s udisks2.service
      21.824s accounts-daemon.service
      21.649s fwupd.service
      16.696s systemd-tmpfiles-clean.service
      16.168s ModemManager.service
      15.824s dev-sda3.device
      14.959s polkit.service
      14.086s avahi-daemon.service
      14.085s bluetooth.service
      14.060s NetworkManager.service
      14.049s dundee.service
      14.018s ofono.service
      13.795s switcheroo-control.service
      13.787s thermald.service
      13.782s wpa_supplicant.service
      13.780s systemd-logind.service
      10.643s systemd-tmpfiles-setup.service
       9.122s user@125.service
       9.110s plymouth-read-write.service
       8.307s dev-loop11.device
       8.275s dev-loop1.device
       8.188s dev-loop8.device
       7.778s dev-loop5.device
       7.385s dev-loop10.device
       7.307s dev-loop9.device
       6.845s dev-loop3.device
       6.568s dev-loop2.device
       6.476s dev-loop4.device
       6.474s dev-loop7.device
       6.210s grub-common.service
       6.074s apport.service
       5.830s systemd-resolved.service
       5.821s bolt.service
       5.818s secureboot-db.service
       5.184s gpu-manager.service
       4.838s gdm.service
       4.580s dev-loop6.device
       4.534s dev-loop0.device
       4.447s rsyslog.service
       4.261s ubuntu-fan.service
       3.503s apparmor.service
       3.407s grub-initrd-fallback.service
       2.575s snap-canonical\x2dlivepatch-95.mount
       2.253s binfmt-support.service
       2.234s snapd.apparmor.service
       2.221s snap-chromium-1399.mount
       2.050s e2scrub_reap.service
       1.964s systemd-rfkill.service
       1.873s snap-core-10185.mount
       1.616s snap-core18-1932.mount
       1.491s pppd-dns.service
       1.478s colord.service
       1.448s snapd.seeded.service
       1.353s upower.service
       1.333s snap-gnome\x2d3\x2d28\x2d1804-145.mount
       1.181s systemd-backlight@backlight:intel_backlight.service
       1.164s systemd-udevd.service
       1.059s snap-gnome\x2d3\x2d34\x2d1804-60.mount
        984ms systemd-fsck@dev-disk-by\x2duuid-565baeeb\x2df53c\x2d44c6\x2da9b3\x2d7604d7b7e16f.service
        949ms systemd-modules-load.service
        908ms apport-autoreport.service
        828ms kerneloops.service
        771ms systemd-random-seed.service
        770ms openvpn.service
        752ms modprobe@drm.service
        749ms snap-gtk\x2dcommon\x2dthemes-1506.mount
        725ms systemd-sysusers.service
        675ms containerd.service
        651ms systemd-udev-trigger.service
        638ms virtualbox.service
        628ms systemd-sysctl.service
        608ms snap-kde\x2dframeworks\x2d5\x2dcore18-32.mount
        600ms snap-simplescreenrecorder\x2dbrlin-69.mount
        588ms systemd-fsck@dev-disk-by\x2duuid-2F60\x2d3524.service
        538ms user@1000.service
        538ms ufw.service
        530ms systemd-journald.service
        513ms snap-slack-32.mount
        467ms systemd-remount-fs.service
        464ms qemu-kvm.service
        414ms systemd-user-sessions.service
        413ms console-setup.service
        396ms plymouth-start.service
        324ms systemd-tmpfiles-setup-dev.service
        308ms systemd-timesyncd.service
        268ms fam.service
        255ms alsa-restore.service
        236ms rtkit-daemon.service
        227ms dev-hugepages.mount
        226ms dev-mqueue.mount
        224ms sys-kernel-debug.mount
        223ms sys-kernel-tracing.mount
        220ms kmod-static-nodes.service
        204ms snap-snap\x2dstore-481.mount
        195ms user-runtime-dir@125.service
        181ms setvtrgb.service
        174ms dev-disk-by\x2duuid-628e5f66\x2dda0b\x2d41af\x2dbaca\x2dc4d1fafee694.swap
        158ms systemd-update-utmp.service
        144ms home.mount
        138ms snap-snapd-9721.mount
        124ms boot-efi.mount
         44ms proc-sys-fs-binfmt_misc.mount
         38ms systemd-update-utmp-runlevel.service
         34ms user-runtime-dir@1000.service
          5ms sys-fs-fuse-connections.mount
          4ms sys-kernel-config.mount
          2ms docker.socket
          1ms snapd.socket
systemd-analyze critical-chain output :
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @3min 9.875s └─multi-user.target @3min 9.875s └─snapd.seeded.service @1min 9.328s +1.448s └─snapd.service @35.652s +33.670s └─basic.target @35.221s └─sockets.target @35.221s └─snapd.socket @35.219s +1ms └─sysinit.target @35.071s └─systemd-timesyncd.service @34.762s +308ms └─systemd-tmpfiles-setup.service @24.029s +10.643s └─local-fs.target @24.017s └─run-snapd-ns-chromium.mnt.mount @12min 46.580s └─run-snapd-ns.mount @57.339s └─swap.target @23.033s └─dev-disk-by\x2duuid-628e5f66\x2dda0b\x2d41af\x2dbaca\x2dc4d1fafee694.swap @22.857s +174ms └─dev-disk-by\x2duuid-628e5f66\x2dda0b\x2d41af\x2dbaca\x2dc4d1fafee694.device @22.854s
cat /etc/fstab output:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda3 during installation
UUID=bc7f56e3-b60c-48a9-b04d-385d9c46c938 /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/sda1 during installation
UUID=2F60-3524  /boot/efi       vfat    umask=0077      0       1
# /home was on /dev/sda4 during installation
UUID=565baeeb-f53c-44c6-a9b3-7604d7b7e16f /home           ext4    defaults        0       2
# swap was on /dev/sda2 during installation
UUID=628e5f66-da0b-41af-baca-c4d1fafee694 none            swap    sw              0       0
I have checked the UUID of the swap.
