How can I switch the Linux kernel package from the System76 repository to using standard Ubuntu repository? My computer has the System76 repository PPA added in addition to the standard Ubuntu 20.04 repositories. Here is a partial output of the apt-cache policy command:
 101 http://ppa.launchpad.net/system76-dev/stable/ubuntu focal/main amd64 Packages
     release v=20.04,o=LP-PPA-system76-dev-stable,a=focal,n=focal,l=System76 Stable PPA,c=main,b=amd64
I changed the priority of this PPA from 1000 to 101 to lower it below the standard Ubuntu repository of 500. My computer still has the Linux kernel installed from the System76 repository. Here is a uname -a output:
Linux laptop 5.8.0-7625-generic #26~1604441536~20.04~a2b1f25~dev-Ubuntu SMP Wed Nov 4 01:19:56 U x86_64 x86_64 x86_64 GNU/Linux
How can I revert to the standard Ubuntu Linux kernel and not have the System76 one try to upgrade over it?
Clarification: I'm not running PopOS. The System76 repository has installed a 5.8 Linux kernel and I'd like to safely switch to the Ubuntu 20.04 standard 5.4 Linux kernel. I think I might need some firmware or device drivers from the System76 repository, so I think I need to keep it enabled.
Jeff
  • 911
The easiest way would be to remove the System76 repositories and change your desktop environment to Gnome.
  1. Log out from your current session
  2. Select your account from the login screen, then choose the "Ubuntu" option from the little gear menu in the bottom right corner to use Gnome, and sign in
  3. Remove any System76 repository references from the /etc/apt/sources.list file
  4. Remove any System76 references from the /etc/apt/sources.list.d/ directory
  5. sudo apt update
That should be it. Then you'll be running stock Ubuntu.
Be warned even with apt pinning it could turn your package management/system into chaos. No warranty from me. For security install ppa-purge first. If something goes bad you can try revert/delete packages with
sudo ppa-purge system76-dev/stable
another way for be prepared is
/etc/apt/preferences.d/focal.pref
Package: *
Pin: release n=focal
Pin-Priority: 1001
for this in
/etc/apt/sources.list.d/system76-dev-ubuntu-stable-focal.list
the entries has to be comment out.
sudo apt full-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
  python3-distupgrade ubuntu-release-upgrader-core ubuntu-release-upgrader-qt
The following packages will be DOWNGRADED:
  accountsservice libaccountsservice0 linux-firmware linux-generic linux-headers-generic linux-image-generic linux-libc-dev ubuntu-drivers-common
  virtualbox virtualbox-dkms virtualbox-qt
3 upgraded, 0 newly installed, 11 downgraded, 0 to remove and 0 not upgraded.
Need to get 43,9 MB/145 MB of archives.
After this operation, 50,5 MB disk space will be freed.
Pinning for kernel
/etc/apt/preferences.d/kernel.pref
# Kernel pinnen
Package: linux-generic Pin: origin security.ubuntu.com Pin-Priority:1001
Package: linux-generic Pin: origin archive.ubuntu.com Pin-Priority: 1001
Package: linux-image-generic Pin: origin security.ubuntu.com Pin-Priority:1001
Package: linux-image-generic Pin: origin archive.ubuntu.com Pin-Priority:1001
Package: linux-headers-generic Pin: origin archive.ubuntu.com Pin-Priority: 1001
Package: linux-headers-generic Pin: origin security.ubuntu.com Pin-Priority: 1001
Package: * Pin: origin ppa.launchpad.net Pin-Priority: 300
Packages for kernel from origin archive.ubuntu.com/security.ubuntu.com are preffered (1001)
0 upgraded, 0 newly installed, 3 downgraded, 0 to remove and 0 not upgraded.
Need to get 0 B/7.028 B of archives.
After this operation, 630 kB disk space will be freed.
Do you want to continue? [Y/n] y
dpkg: warning: downgrading linux-generic from 5.8.0.7630.32~1605108853~20.04~8bcf10e~dev to 5.4.0.54.57
(Reading database ... 291830 files and directories currently installed.)
Preparing to unpack .../linux-generic_5.4.0.54.57_amd64.deb ...
Unpacking linux-generic (5.4.0.54.57) over (5.8.0.7630.32~1605108853~20.04~8bcf10e~dev) ...
dpkg: warning: downgrading linux-image-generic from 5.8.0.7630.32~1605108853~20.04~8bcf10e~dev to 5.4.0.54.57
Preparing to unpack .../linux-image-generic_5.4.0.54.57_amd64.deb ...
Unpacking linux-image-generic (5.4.0.54.57) over (5.8.0.7630.32~1605108853~20.04~8bcf10e~dev) ...
dpkg: warning: downgrading linux-headers-generic from 5.8.0.7630.32~1605108853~20.04~8bcf10e~dev to 5.4.0.54.57
Preparing to unpack .../linux-headers-generic_5.4.0.54.57_amd64.deb ...
Unpacking linux-headers-generic (5.4.0.54.57) over (5.8.0.7630.32~1605108853~20.04~8bcf10e~dev) ...
Setting up linux-image-generic (5.4.0.54.57) ...
Setting up linux-headers-generic (5.4.0.54.57) ...
Setting up linux-generic (5.4.0.54.57) ...
you get for all other packages from your ppa updates for installt packages.
Note remaining kernel/headermodules packages from ppa you have to purge on your own.
You can do it on your own risk. Really. Be warned
Better is to remove the ppa with ppa-purge. Remove all apt pinning files.
Reactivate the ppa again. then create
/etc/apt/preferences.d/system76.pref
# pinning für system-dev
Package: *
Pin: release o=LP-PPA-system76-dev-stable,a=focal
Pin-Priority: 300
If you need a particular package from ppa you can install it like this.
apt-get -s install -t focal linux-firmware
NOTE: This is only a simulation!
      apt-get needs root privileges for real execution.
      Keep also in mind that locking is deactivated,
      so don't depend on the relevance to the real current situation!
  linux-firmware
1 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
Inst linux-firmware [1.187.4] (1.190.1+system76~1605123765~20.04~3894207~dev System76 Stable PPA:20.04/focal [all])
Conf linux-firmware (1.190.1+system76~1605123765~20.04~3894207~dev System76 Stable PPA:20.04/focal [all])
Another example
apt-get -s install -t focal accountsservice
The following additional packages will be installed:
  libaccountsservice0
Suggested packages:
  gnome-control-center
2 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
Inst accountsservice [0.6.55-0ubuntu12~20.04.4] (0.6.55-0ubuntu13.2pop0~1605745773~20.04~d9482b1~dev System76 Stable PPA:20.04/focal [amd64]) []
Inst libaccountsservice0 [0.6.55-0ubuntu12~20.04.4] (0.6.55-0ubuntu13.2pop0~1605745773~20.04~d9482b1~dev System76 Stable PPA:20.04/focal [amd64])
Conf accountsservice (0.6.55-0ubuntu13.2pop0~1605745773~20.04~d9482b1~dev System76 Stable PPA:20.04/focal [amd64])
Conf libaccountsservice0 (0.6.55-0ubuntu13.2pop0~1605745773~20.04~d9482b1~dev System76 Stable PPA:20.04/focal [amd64])
nobody
  • 5,792
