I have Ubuntu 18.04 installed on my Acer Nitro 5 notebook, and I'm using the NVIDIA driver metapackage nvidia-driver-450. I'm observing a lot of screen tearing in my external monitor, connected to the notebook via HDMI cable. I can observe it in videos and when I drag windows around. However, there is no screen tearing on the notebook monitor, only on the external one.
I have already tried the options nvidia-drm modeset=1 solution, it solved the screen tearing only for the notebook monitor, but not the external one.
I also have tried setting "Force Composition Pipeline" in the NVIDIA X Server Settings, it solves the issue, but when I restart the system the notebook monitor stops being recognized (the screen is black, and it is not listed in xrandr). It seems like it is because the Notebook monitor is a PRIME Display, as shown in the link below, and it can't deal with the X Configuration File that the X Server generates.
NVIDIA X Server Settings image
Can someone help me? The only thing I haven't tried yet is using the X X.Org Server (xserver-xorg-video-nouveau), but I didn't want to use it because I have an GTX 1650, and I understand the Nouveau isn't that good.
AmandaB
So, with the help of this, this and this post, I was able to find a workaround. Since using "Force Composition Pipeline" in NVIDIA X Server stops the screen tearing, but makes the notebook monitor stop being recognized, the workaround is to run the Force Composition Pipeline command after every startup.
I just added the command bash -c "sleep 10 && nvidia-settings --assign CurrentMetaMode=\"$(xrandr | sed -nr '/(\S+) connected (primary )?([0-9]+x[0-9]+)(\+\S+).*/{ s//\1: \3 \4 { ForceCompositionPipeline = On }, /; H}; ${ g; s/\n//g; s/, $//; p }')\"" (found in this post) in the startup commands, and now the second monitor has no screen tearing, and I have no problems after shutting the notebook down.
AmandaB
I let the nvidia-settings generate a conf file. That file was copied to: /etc/X11/xorg.conf.d/90-dual.conf.
You might have to setup both monitors in your config. See here for an example. Note that I've configured
Option "Xinerama" "0"
in the "ServerLayout" section
The following contents may not apply to your monitor, but it might give a gist how it should look like. After copying that file you need to reboot...
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files" EndSection
Section "Module" Load "dbe" Load "extmod" Load "type1" Load "freetype" Load "glx" EndSection
Section "InputDevice" # generated from default Identifier "Mouse0" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/psaux" Option "Emulate3Buttons" "no" Option "ZAxisMapping" "4 5" EndSection
Section "InputDevice" # generated from default Identifier "Keyboard0" Driver "kbd" EndSection
Section "Monitor" # HorizSync source: edid, VertRefresh source: edid Identifier "Monitor0" VendorName "Unknown" ModelName "<your monitor here>" HorizSync 30.0 - 83.0 VertRefresh 55.0 - 76.0 Option "DPMS" EndSection
Section "Device" Identifier "Device0" Driver "nvidia" VendorName "NVIDIA Corporation" BoardName "GeForce <your version here>" EndSection
Section "Screen" Identifier "Screen0" Device "Device0" Monitor "Monitor0" DefaultDepth 24 Option "Stereo" "0" Option "nvidiaXineramaInfoOrder" "DFP-0" Option "metamodes" "DVI-I-1: nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}, DVI-D-0: nvidia-auto-select +1920+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}" Option "SLI" "Off" Option "MultiGPU" "Off" Option "BaseMosaic" "off" SubSection "Display" Depth 24 EndSubSection EndSection
kanehekili
  • 7,426
