I have Ubuntu 20.04 installed on my Lenovo Y7000P2020H laptop alongside Windows 10. I can adjust my screen brightness in Windows but not in Ubuntu 20.04. Neither the fn keys nor the brightness scroll bar works.
More specific system information:
- Laptop model: Lenovo Y7000P2020H
- OS: Ubuntu 20.04.1 LTS
- CPU: Interl Core i7-10750H CPU@1.60GHzx12
- GPU: Nvidia RTX2060, Graphics Device/PCIe/SSE2
- GNOME: 3.36.3
- Windowing System: X11
I'd really like a solution that make the fn keys work. Please don't suggest brightness-controller and other methods that I have to use command lines. I've tried them and they are really inconvenient for me.
I've practically tried every solution I can find online, but nothing works:
1. Modifying /etc/default/grub
As suggested in various posts, I've tried
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=Linux"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=native"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash video.use_native_backlight=1"
Neither works.
2. xbacklight control, as in the first solution of this answer
Got stuck at step 5 with an error message:
ln: failed to create symbolic link '/sys/class/brightness': Operation not permitted
3 Creating usr/share/X11/xorg.conf.d/20-intel.conf, as in the second solution of this answer
This results in small green and purple blocks to appear on my screen.
4 Change default graphics card using prime-select
I did prime-select intel. After reboot the Nvidia GPU becomes unavailable:
user@pcname:~$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
None of these works. But during the attempts I started to have the suspicion that my screen may be using the Nvidia graphics card for displaying and not the graphics card integrated in my Intel CPU.
One reason is that there are always two Xorg processes running on my Nvidia GPU:
Mon Nov 16 10:52:35 2020
| NVIDIA-SMI 440.33.01 Driver Version: 440.33.01 CUDA Version: 10.2 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 Graphics Device On | 00000000:01:00.0 Off | N/A |
| N/A 43C P8 4W / N/A | 346MiB / 5934MiB | 10% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1188 G /usr/lib/xorg/Xorg 45MiB |
| 0 1977 G /usr/lib/xorg/Xorg 110MiB |
| 0 2160 G /usr/bin/gnome-shell 105MiB |
| 0 2634 G ...AAAAAAAAAAAACAAAAAAAAAA= --shared-files 67MiB |
| 0 5309 G gnome-control-center 3MiB |
Moreover, in /usr/share/X11/xorg.conf.d/ there is no config file related to intel, but there are a few with nvidia in their names:
user@pcname:/usr/share/X11/xorg.conf.d$ ls
10-amdgpu.conf 10-quirks.conf 11-nvidia-prime.conf 70-wacom.conf
10-nvidia.conf 10-radeon.conf 40-libinput.conf
In 10-nvidia.conf:
Section "OutputClass"
Identifier "nvidia"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "AllowEmptyInitialConfiguration"
Option "EnableBrightnessControl=1"
ModulePath "/usr/lib/x86_64-linux-gnu/nvidia-440/xorg"
EndSection
In `11-nvidia-prime.conf':
# DO NOT EDIT. AUTOMATICALLY GENERATED BY gpu-manager
Identifier "Nvidia Prime"
Driver "nvidia"
Option "IgnoreDisplayDevices" "CRT"
Option "PrimaryGPU" "Yes"
ModulePath "/lib/x86_64-linux-gnu/nvidia/xorg"
EndSection
In 10-amdgpu.conf:
Identifier "AMDgpu"
MatchDriver "amdgpu"
Driver "amdgpu"
EndSection
I suppose something went wrong in these configurations?
Any help is greatly appreciated!
