Having previously installed an Ubuntu 18.04 server I expected no problems with using the sudo apt update command. However my recent install of Ubuntu 18.04.5 has a problem installing updates using the apt command, it simply doesn't seem to work for anything allowing standard package installations/updates/upgrades.
I subsequently modified my sources.list file to attempt to install webmin and that did allow me to download from the source site for that package.
I then tried pinging the sources.list sites which are in the sources.list file, and was successful in returning pings from those sites.
Still after that webmin package download I was not able to successfully use the sudo apt update command. I received the following messages:
$ sudo apt update
Err:1 http://us.archive.ubuntu.com/ubuntu bionic InRelease
  Could not connect to banjo.canonical.com:80 (91.189.91.38), connection timed out Could not connect to kazooie.canonical.com:80 (91.189.91.39), connection timed out Unable to connect to us.archive.ubuntu.com:http:
Err:2 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
Err:3 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
Err:4 http://us.archive.ubuntu.com/ubuntu bionic-security InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/bionic/InRelease  Could not connect to banjo.canonical.com:80 (91.189.91.38), connection timed out Could not connect to kazooie.canonical.com:80 (91.189.91.39), connection timed out Unable to connect to us.archive.ubuntu.com:http:
W: Some index files failed to download. They have been ignored, or old ones used instead.
I am wondering if anyone has seen this problem and if anyone has suggestion towards a solution?
Kulfy
  • 18,154
Tobor
This problem affected my whole network and was solved when my ISP rebooted equipment associated with my service.
Consider this problem solved not as an Ubuntu issue but rather one due to my ISP.
Thank you to those who sought to help me.
Tobor
