I had removed my linux from my system but had not removed GRUB.Everytime i power on my laptop i have to type exit to load up windows.I am unable to find a proper fix for this i have windows 10 Home.How can i remove GRUB and boot directly to my windows?
Asked
Active
Viewed 2.9k times
Assuming you have deleted all the partitions linux was in (if you haven't you can do it from windows later) you will need to make the windows bootloader the standard, the easiest way of doing this is with windows itself, you should make a new windows recovery usb, and then use it to repair the bootloader.
You should boot your system from the recovery usb (the way to do this depends on your particular system) and then do the following:
- Click on the Repair your Computer link at the bottom of the Install Now screen.
- Click on Troubleshoot
- Select Command Prompt
- Enter the following three commands in turn, following each by pressing the Enter key:
bootrec /fixmbr
bootrec /fixboot
bootrec /rebuildbcd
- Restart the PC with the installation media removed to check if the repair worked
SantiMar
- 31
Delete the entire partition that you had installed linux on it or just forms=at it. Windows partition will be safe and you have deleted linux
Python is cool
- 144
