When I run sudo apt install lutris then I get this error message
You might want to run 'apt --fix-broken install' to correct these.
 libc6-dbg : Depends: libc6 (= 2.27-3ubuntu1.3) but 2.27-3ubuntu1.2 is to be installed
 libc6-dev : Depends: libc6 (= 2.27-3ubuntu1.3) but 2.27-3ubuntu1.2 is to be installed
 lutris : Depends: python3-setproctitle but it is not going to be installed
          Depends: python3-distro but it is not going to be installed
          Depends: fluid-soundfont-gs but it is not going to be installed
          Depends: mesa-utils but it is not going to be installed
          Recommends: libc6-i386 but it is not going to be installed
          Recommends: lib32gcc1 but it is not going to be installed or
                      lib32gcc-s1 but it is not installable
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
so as you might expect I ran sudo apt --fix-broken install and then I get this error message
 /var/cache/apt/archives/libc6_2.27-3ubuntu1.3_amd64.deb
 /var/cache/apt/archives/libc6_2.27-3ubuntu1.3_i386.deb
what do I do?
The current libc6 version is 2.31-4, I believe. Maybe ubfan1 is right. Try.
sudo apt update && sudo apt upgrade
