I've been using X2Go for a while now to connect from Windows10 to remote Ubuntu server.
I've been using the X2Go Session Type "Connect to local desktop".
Everything was working last night. Today when I tried connecting the X2Go Client seems to connect. However, where the X2Go Client GUI normally displays the Ubuntu desktop, I get a black screen which temporarily shows X2Go logo/name.
There are quite a few pages related to X2Go Black Screen, but I couldn't find an answer to my problem. Here are a few I looked: x2go do not connect to active desktop session X2go Black Screen
While ssh'd into remote machine using putty simultaneously while X2Go client is connected and showing black screen, if I run x2golistdesktops from terminal, I see
theusername@:50
theusername@:1
I think the theusername@:50 is the X2Go connection. This concerns me b/c in info reported by X2Go client (see below) I see Info: Forwarding X11 connections to display 'localhost:0'.
I've tried restarted my local machine. I've also restarted the X2Go service on the remote Ubuntu machine. I was also able to connect to remote machine using putty with x11 forwarding and xming and get GUI (e.g. for emacs).
Here is info reported by X2Go:
Copyright (C) 2001, 2010 NoMachine.
See http://www.nomachine.com/ for more information.
Info: Proxy running in client mode with pid '7496'.
Session: Starting session at 'Fri Nov 13 11:28:10 2020'.
Info: Connecting to remote host 'localhost:58746'.
Info: Connection to remote proxy 'localhost:58746' established.
Info: Connection with remote proxy completed.
Warning: Unrecognized session type 'unix-kde-depth_32'. Assuming agent session.
Warning: Failed to read data from the X auth command.
Warning: Generated a fake cookie for X authentication.
Info: Using ADSL link parameters 512/24/1/0.
Info: Using cache parameters 4/4096KB/8192KB/8192KB.
Info: Using pack method '16m-jpeg-9' with session 'unix-kde-depth_32'.
Info: Using ZLIB data compression 1/1/32.
Info: Using ZLIB stream compression 4/4.
Info: No suitable cache file found.
Session: Session started at 'Fri Nov 13 11:28:12 2020'.
Info: Established X server connection.
Info: Using shared memory parameters 0/0K.
