After updating ubuntu 16 to ubuntu 20.04.1 the wired connection keeps disconnecting randomly.
The solution is manually turn off and on the connection from the upper left button. However, I am working remotely and that is not an option anymore.
I have tried solutions like this but they do not work for me.
This is the output of some commands that I think they might be useful when the connection is not working:
ifconfig:
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet6 fe80::896d:d145:fe49:db08  prefixlen 64  scopeid 0x20<link>
        inet6 2a0c:5bc0:40:1028:df60:8e5c:3fb0:a0dd  prefixlen 64  scopeid 0x0<global>
        inet6 2a0c:5bc0:40:1028:60f4:f459:9371:5e6e  prefixlen 64  scopeid 0x0<global>
        inet6 2a0c:5bc0:40:1028:4597:f3aa:b00c:62bb  prefixlen 64  scopeid 0x0<global>
        ether 18:60:24:8b:fe:32  txqueuelen 1000  (Ethernet)
        RX packets 65344897  bytes 10798738778 (10.7 GB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 1644328  bytes 1140060185 (1.1 GB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 20  memory 0xf3100000-f3120000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 90170 bytes 10380905 (10.3 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 90170 bytes 10380905 (10.3 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
nmcli d:
DEVICE  TYPE      STATE      CONNECTION
eno1    ethernet  connected  Wired connection 1
lo      loopback  unmanaged  --
cat /etc/NetworkManager/NetworkManager.conf:
[main]
plugins=ifupdown,keyfile
[ifupdown] managed=true
[device] wifi.scan-rand-mac-address=no
nmcli:
eno1: connected to Wired connection 1
        "Intel Ethernet"
        ethernet (e1000e), 18:60:24:8B:FE:32, hw, mtu 1500
        ip4 default, ip6 default
        inet6 2a0c:5bc0:40:1028:4597:f3aa:b00c:62bb/64
        inet6 2a0c:5bc0:40:1028:60f4:f459:9371:5e6e/64
        inet6 2a0c:5bc0:40:1028:df60:8e5c:3fb0:a0dd/64
        inet6 fe80::896d:d145:fe49:db08/64
        route6 2a0c:5bc0:40:1028::/64
        route6 ::/0
        route6 ff00::/8
        route6 fe80::/64
lo: unmanaged "lo" loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
EDIT
I set managed=false in /etc/NetworkManager/NetworkManager.conf and reboot. This is the output of some commands when the connection is working:
cat /etc/network/interfaces:
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
sudo lshw -C network:
  *-network
       description: Ethernet interface
       product: Ethernet Connection (2) I218-LM
       vendor: Intel Corporation
       physical id: 19
       bus info: pci@0000:00:19.0
       logical name: eno1
       version: 05
       serial: 18:60:24:8b:fe:32
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.1-4 ip=155.198.45.81 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:33 memory:f3100000-f311ffff memory:f313b000-f313bfff ioport:2040(size=32)
EDIT
These are the captures of the wired settings:
details tab identity tab IPv4 tab IPv6 tab
EDIT
This is the output of ls -al /etc/NetworkManager/system-connections/Wired*:
-rw------- 1 root root 261 Nov 16 16:06 '/etc/NetworkManager/system-connections/Wired connection 1.nmconnection'
