I'm using Ubuntu 18.04 and a printer HP Color Laserjet pro mfp m281fdw. Printing works, but scanning does not.
In order to fix the missing scanning function I thought I would update my HPLIP and install the latest hplip-3.20.9.run.
I used the file from https://developers.hp.com/hp-linux-imaging-and-printing and followed the instructions for an automated installation.
Unfortunately, the installation doesn't finish. It doesn't go any further for several hours than...
SECURITY PACKAGES
AppArmor is installed.
AppArmor protects the application from external intrusion attempts making the application secure
Would you like to have this installer install the hplip specific policy/profile (y=yes*, n=no, q=quit) ? y
RUNNING PRE-INSTALL COMMANDS
OK
RUNNING HPLIP LIBS REMOVE COMMANDS
sudo apt-get remove libhpmud0 libsane-hpaio
just rotating and rotatating. No error message. ...
UPDATE I stopped the not ending installation process. And did
hp-check -r
dpkg -l | egrep HP
So I found out that I have indeed fractions of different hplip versions ...
And I did
sudo apt purge hplip hplip-data
to get rid of hplip before reinstalling a new version. (I hope this was OK.) This command results in the following:
[sudo] Password for burkhard:
Reading package list ... Done
Building dependency tree.
Reading status information.... Done
The following packages were installed automatically and are no longer needed:
  libdrm-amdgpu1:i386 libdrm-intel1:i386 libdrm-nouveau2:i386
  libdrm-radeon1:i386 libdrm2:i386 libelf1:i386 libfwup1 libglvnd0:i386
  libllvm9 libpciaccess0:i386 libsane-hpaio libsensors4:i386 libx11-xcb1:i386
  libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386
  libxcb-sync1:i386 libxdamage1:i386 libxshmfence1:i386
  linux-hwe-5.4-headers-5.4.0-42 linux-hwe-5.4-headers-5.4.0-45
  linux-hwe-5.4-headers-5.4.0-47 linux-hwe-5.4-headers-5.4.0-48
  linux-hwe-5.4-headers-5.4.0-51 python3-pexpect python3-ptyprocess
  python3-renderpm python3-reportlab python3-reportlab-accel
  tuxedo-keyboard-dkms
Use 'sudo apt autoremove'  to remove them.
The following packages will be removed:
  hplip* hplip-data* printer-driver-postscript-hp*
0 updated, 0 newly installed, 3 to be removed and 7 not updated.
3 not fully installed or removed.
After this operation 12.9 MB of disk space will be freed.
Do you want to continue? Y/n] Y
(Reading database ... 408916 files and directories are currently installed)
Removing printer-driver-postscript-hp (3.17.10+repack0-5) ...
Removing hplip (3.17.10+repack0-5) ...
Removing von hplip-data (3.17.10+repack0-5) ...
dpkg: Warnung: Während Entfernens von hplip-data ist Verzeichnis »/usr/share/hplip/data/images/other« nicht leer, wird daher nicht gelöscht
dpkg: Warnung: Während Entfernens von hplip-data ist Verzeichnis »/usr/share/hplip/base« nicht leer, wird daher nicht gelöscht
jitsi-meet-prosody (1.0.4466-1) wird eingerichtet ...
The given hostname does not exist in the config
dpkg: Fehler beim Bearbeiten des Paketes jitsi-meet-prosody (--configure):
 »installiertes jitsi-meet-prosody-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 1 zurück
dpkg: Abhängigkeitsprobleme verhindern Konfiguration von jitsi-meet:
 jitsi-meet hängt ab von jitsi-meet-prosody (= 1.0.4466-1); aber:
  Paket jitsi-meet-prosody ist noch nicht konfiguriert.
dpkg: Error while editing the package jitsi-meet (--configure): dependency problems - is unconfigured dpkg: Dependency problems prevent configuration of jitsi-meet-turnserver: jitsi-meet-turnserver depends on jitsi-meet-prosody; but: package jitsi-meet-prosody is not configured yet.
dpkg: Error while editing the package jitsi-meet-turnserver (--configure): dependency problems - is unconfigured Processing triggers for dbus (1.12.2-1ubuntu1.2) ... Processing triggers for cups (2.2.7-1ubuntu2.8) ... Processing triggers for man-db (2.8.3-2ubuntu0.1) ... Errors occurred while editing: jitsi-meet-prosody jitsi-meet jitsi-meet-turnserver E: Sub-process /usr/bin/dpkg returned an error code (1)
I remember that an unfinished jitsi installation has caused installation problems with other installations.
I guess before I run hplip-3.20.9.run I should clean the unfinished jitsi leftover pieces from my configuration. How do I clean this?
karel
  • 122,292
  • 133
  • 301
  • 332
Burkhard
  • 31
