I update my ubuntu recenly to 20.04. now it takes a long time to boot. I have I5 CPU and 8G RAM.
Here the cmd systemd-analyze blame output:
1min 30.094s nmbd.service
     47.725s plymouth-quit-wait.service
     22.834s udisks2.service
     22.771s networkd-dispatcher.service
     19.079s snapd.service
     16.775s dev-sda6.device
     16.618s accounts-daemon.service
     15.567s NetworkManager-wait-online.service
     11.738s polkit.service
     11.591s avahi-daemon.service
     11.590s bluetooth.service
     11.498s NetworkManager.service
     10.792s switcheroo-control.service
     10.786s thermald.service
     10.782s systemd-logind.service
     10.780s wpa_supplicant.service
      9.671s ModemManager.service
      7.797s dev-loop0.device
      7.371s dev-loop1.device
      6.890s dev-loop2.device
      6.884s fwupd.service
      6.669s dev-loop4.device
      5.474s systemd-journal-flush.service
      5.311s dev-loop3.device
      5.240s bolt.service
      4.621s systemd-resolved.service
      4.481s ufw.service
      3.997s rsyslog.service
      3.761s apport.service
      3.673s gpu-manager.service
      3.362s systemd-udevd.service
      3.018s grub-common.service
      2.985s e2scrub_reap.service
      2.829s systemd-tmpfiles-setup.service
      2.615s gdm.service
      2.605s grub-initrd-fallback.service
      2.412s networking.service
      2.334s apparmor.service
      1.970s secureboot-db.service
      1.919s lm-sensors.service
      1.549s snapd.seeded.service
      1.427s virtualbox.service
      1.419s dictd.service
      1.388s systemd-sysusers.service
      1.360s keyboard-setup.service
      1.333s systemd-modules-load.service
      1.328s systemd-fsck@dev-disk-by\x2duuid-CEF1\x2d926B.service
      1.314s colord.service
      1.221s ccpd.service
      1.004s systemd-tmpfiles-setup-dev.service
       997ms systemd-random-seed.service
       888ms systemd-sysctl.service
       794ms modprobe@drm.service
       789ms smbd.service
       770ms snapd.apparmor.service
       755ms binfmt-support.service
       646ms upower.service
       639ms systemd-backlight@backlight:intel_backlight.service
       633ms systemd-rfkill.service
       580ms winbind.service
       542ms snap-core18-1932.mount
       516ms pppd-dns.service
       412ms systemd-udev-trigger.service
       407ms systemd-timedated.service
       384ms snap-snap\x2dstore-481.mount
       351ms kerneloops.service
       335ms ifupdown-pre.service
       275ms systemd-timesyncd.service
       274ms rc-local.service
       231ms kmod-static-nodes.service
       218ms console-setup.service
       217ms user@1000.service
       213ms snap-gnome\x2d3\x2d34\x2d1804-60.mount
       200ms snap-gtk\x2dcommon\x2dthemes-1506.mount
       200ms systemd-remount-fs.service
       200ms systemd-journald.service
       195ms openvpn.service
       182ms dev-hugepages.mount
       182ms dev-mqueue.mount
       180ms sys-kernel-debug.mount
       180ms sys-kernel-tracing.mount
       156ms dev-disk-by\x2duuid-0dddf165\x2d43ec\x2d452e\x2d9e15\x2da64e2699cdfa.swap
       153ms snap-snapd-9721.mount
       141ms proc-sys-fs-binfmt_misc.mount
       139ms plymouth-start.service
       133ms systemd-user-sessions.service
       126ms setvtrgb.service
       117ms dns-clean.service
       116ms systemd-update-utmp.service
       110ms boot-efi.mount
       106ms rtkit-daemon.service
        69ms hddtemp.service
        67ms systemd-tmpfiles-clean.service
        55ms plymouth-read-write.service
        49ms user-runtime-dir@1000.service
        45ms resolvconf-pull-resolved.service
        41ms systemd-update-utmp-runlevel.service
        16ms alsa-restore.service
         4ms sys-fs-fuse-connections.mount
         3ms sys-kernel-config.mount
         1ms snapd.socket
and systemd-analyze critical-chain output
    graphical.target @2min 25.659s
    └─multi-user.target @2min 25.658s
      └─smbd.service @2min 24.867s +789ms
        └─winbind.service @2min 24.280s +580ms
          └─network.target @38.518s
            └─NetworkManager.service @27.019s +11.498s
              └─dbus.service @27.013s
                └─basic.target @26.670s
                  └─sockets.target @26.670s
                    └─snapd.socket @26.668s +1ms
                      └─sysinit.target @26.291s
                        └─systemd-timesyncd.service @26.015s +275ms
                          └─systemd-tmpfiles-setup.service @23.107s +2.829s
                            └─local-fs.target @22.985s
                              └─boot-efi.mount @22.875s +110ms
                                └─systemd-fsck@dev-disk-by\x2duuid-CEF1\x2d926B.service @21.528s +1.328s
                                  └─dev-disk-by\x2duuid-CEF1\x2d926B.device @21.526s
Here systemd-analyze plot result.
Is there a solution to this problem?
Ak.tech
  • 81
  • Evaluate if you can remove sda drive, if not, evaluate what is loaded from sda6 and migrate it on a faster storage.
  • Evaluate if you can uninstall/remove your snaps packages.
  • Evaluate if you really need virtualbox to start at boot
  • Check your nmdb settings, if the machine is not hosting smb shares, connecting to smb shares, not part of a Microsoft Active Directory, consider uninstalling nmdb and purging its configuration in case you reinstall it in the future.
  • Check your WiFi drivers and WiFi configuration
  • Check your network connection while booting, as your machine is waiting for it.
mchid
  • 44,904
  • 102
  • 162
Zulgrib
  • 263
It looks like 2 specific events are slowing it down:
  1. it is waiting for the network connection to become available
  2. it is waiting for winbind/nmbd to do something, possible get a list of all host names on your network
Removing winbind/nmbd or disabling those services should speed it up significantly.
The network wait time seems to be 11s out of your huge delay, but as long as you are not automounting smb or nfs, or are using LDAP for login, you can skip that, and save the 11s
muru
  • 207,228
