I am preparing migration of an UBUNTU 16.04.7 server with 5 NIC's to 20.04. My testing server has 4 NIC's: 2 onboard and 2 as Intel Pro NIC. Configured in 00-installer-config.yaml. The first NIC is configured as:
  version: 2
  renderer: networkd
  ethernets:
    enp65s0f0:
      addresses: [10.1.11.230/24]
      gateway4: 10.1.11.11
      nameservers:
        addresses: [10.1.11.11, 1.1.1.1]
    enp193s0f0:
      optional: true
    enp193s0f1:
      optional: true
    enp65s0f1:
      optional: true
This part works. The next 3 NIC's are going to be bond0, with vlans on top and bridges:
  bonds:
    bond0:
      interfaces: [enp193s0f0, enp193s0f1, enp65s0f1]
      parameters:
        mode: 802.3ad
        lacp-rate: fast
        mii-monitor-interval: 100
        min-links: 1
  vlans:
    vlan1:
      link: bond0
    vlan11:
      link: bond0
    vlan240:
      link: bond0
  bridges:
    br100:
      interfaces: [vlan1]
    br11:
      interfaces: [vlan11]
    br240:
      interfaces: [vlan240]
The bond0 does not work. I have searched and tried all kinds of variations with ordering of NIC's, dhcp4: false, dhcp6: false, optional:true only using the IntelPro NIC's for the bonding. I have reviewed answers on this and other forums, but no solution so far yet.
  • What's wrong with my configuration? Anything missing?
  • Is the architecture I am aiming at still supported? I want my KVM guests to use a bridge so they can communicate with each other without needing the physical switch and without needing VLAN to be configured in the guests. This worked perfectly in Ub16.04.
My switch is a HP V1910-24G and has 4 other working trunks (LACP/802.3ad), with the Ub16.04 (4 NIC's)server and 3 QNAP NAS's with each a double NIC.
See the following outputs on my Ubuntu 20.04 with the above netplan config:
networkctl list
IDX LINK       TYPE     OPERATIONAL SETUP
  1 lo         loopback carrier     unmanaged
  2 enp65s0f0  ether    routable    configured
  3 enp65s0f1  ether    enslaved    configured
  4 enp193s0f0 ether    enslaved    configured
  5 enp193s0f1 ether    enslaved    configured
  6 bond0      bond     degraded    configured
  7 br100      bridge   degraded    configured
  8 br11       bridge   degraded    configured
  9 br240      bridge   degraded    configured
 10 vlan.240   vlan     carrier     unmanaged
 11 vlan.11    vlan     carrier     unmanaged
 12 vlan.1     vlan     carrier     unmanaged
 13 virbr0     bridge   no-carrier  unmanaged
 14 virbr0-nic ether    off         unmanaged
 17 vnet0      ether    degraded    unmanaged
ip link 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2: enp65s0f0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000 link/ether d0:50:99:d4:bc:e3 brd ff:ff:ff:ff:ff:ff 3: enp65s0f1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master bond0 state UP mode DEFAULT group default qlen 1000 link/ether 16:3d:9c:75:6b:c5 brd ff:ff:ff:ff:ff:ff 4: enp193s0f0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc fq_codel master bond0 state UP mode DEFAULT group default qlen 1000 link/ether 16:3d:9c:75:6b:c5 brd ff:ff:ff:ff:ff:ff 5: enp193s0f1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc fq_codel master bond0 state UP mode DEFAULT group default qlen 1000 link/ether 16:3d:9c:75:6b:c5 brd ff:ff:ff:ff:ff:ff 6: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000 link/ether 16:3d:9c:75:6b:c5 brd ff:ff:ff:ff:ff:ff 7: br100: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000 link/ether 16:3d:9c:75:6b:c5 brd ff:ff:ff:ff:ff:ff 8: br11: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000 link/ether 16:3d:9c:75:6b:c5 brd ff:ff:ff:ff:ff:ff 9: br240: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000 link/ether 16:3d:9c:75:6b:c5 brd ff:ff:ff:ff:ff:ff 10: vlan.240@bond0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br240 state UP mode DEFAULT group default qlen 1000 link/ether 16:3d:9c:75:6b:c5 brd ff:ff:ff:ff:ff:ff 11: vlan.11@bond0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br11 state UP mode DEFAULT group default qlen 1000 link/ether 16:3d:9c:75:6b:c5 brd ff:ff:ff:ff:ff:ff 12: vlan.1@bond0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br100 state UP mode DEFAULT group default qlen 1000 link/ether 16:3d:9c:75:6b:c5 brd ff:ff:ff:ff:ff:ff 13: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default qlen 1000 link/ether 52:54:00:f4:49:5c brd ff:ff:ff:ff:ff:ff 14: virbr0-nic: <BROADCAST,MULTICAST> mtu 1500 qdisc fq_codel master virbr0 state DOWN mode DEFAULT group default qlen 1000 link/ether 52:54:00:f4:49:5c brd ff:ff:ff:ff:ff:ff 17: vnet0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel master br11 state UNKNOWN mode DEFAULT group default qlen 1000 link/ether fe:54:00:d2:56:7d brd ff:ff:ff:ff:ff:ff
netplan --debug apply ** (generate:11473): DEBUG: 13:54:31.627: Processing input file /etc/netplan/00-installer-config.yaml.. ** (generate:11473): DEBUG: 13:54:31.628: starting new processing pass ** (generate:11473): DEBUG: 13:54:31.628: We have some netdefs, pass them through a final round of validation ** (generate:11473): DEBUG: 13:54:31.628: vlan240: setting default backend to 1 ** (generate:11473): DEBUG: 13:54:31.628: Configuration is valid ** (generate:11473): DEBUG: 13:54:31.628: bond0: setting default backend to 1 ** (generate:11473): DEBUG: 13:54:31.628: Configuration is valid ** (generate:11473): DEBUG: 13:54:31.628: br11: setting default backend to 1 ** (generate:11473): DEBUG: 13:54:31.628: Configuration is valid ** (generate:11473): DEBUG: 13:54:31.628: enp65s0f1: setting default backend to 1 ** (generate:11473): DEBUG: 13:54:31.628: Configuration is valid ** (generate:11473): DEBUG: 13:54:31.628: enp65s0f0: setting default backend to 1 ** (generate:11473): DEBUG: 13:54:31.628: Configuration is valid ** (generate:11473): DEBUG: 13:54:31.628: vlan11: setting default backend to 1 ** (generate:11473): DEBUG: 13:54:31.628: Configuration is valid ** (generate:11473): DEBUG: 13:54:31.628: enp193s0f1: setting default backend to 1 ** (generate:11473): DEBUG: 13:54:31.628: Configuration is valid ** (generate:11473): DEBUG: 13:54:31.628: br100: setting default backend to 1 ** (generate:11473): DEBUG: 13:54:31.628: Configuration is valid ** (generate:11473): DEBUG: 13:54:31.628: vlan1: setting default backend to 1 ** (generate:11473): DEBUG: 13:54:31.628: Configuration is valid ** (generate:11473): DEBUG: 13:54:31.628: enp193s0f0: setting default backend to 1 ** (generate:11473): DEBUG: 13:54:31.628: Configuration is valid ** (generate:11473): DEBUG: 13:54:31.628: br240: setting default backend to 1 ** (generate:11473): DEBUG: 13:54:31.628: Configuration is valid ** (generate:11473): DEBUG: 13:54:31.628: Generating output files.. ** (generate:11473): DEBUG: 13:54:31.629: openvswitch: definition enp65s0f0 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: NetworkManager: definition enp65s0f0 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: openvswitch: definition enp193s0f0 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: NetworkManager: definition enp193s0f0 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: openvswitch: definition enp193s0f1 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: NetworkManager: definition enp193s0f1 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: openvswitch: definition enp65s0f1 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: NetworkManager: definition enp65s0f1 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: openvswitch: definition bond0 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: NetworkManager: definition bond0 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: openvswitch: definition vlan1 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: NetworkManager: definition vlan1 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: openvswitch: definition vlan11 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: NetworkManager: definition vlan11 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: openvswitch: definition vlan240 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: NetworkManager: definition vlan240 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: openvswitch: definition br100 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: NetworkManager: definition br100 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: openvswitch: definition br11 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: NetworkManager: definition br11 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: openvswitch: definition br240 is not for us (backend 1) ** (generate:11473): DEBUG: 13:54:31.629: NetworkManager: definition br240 is not for us (backend 1) (generate:11473): GLib-DEBUG: 13:54:31.629: posix_spawn avoided (fd close requested) (generate:11473): GLib-DEBUG: 13:54:31.630: posix_spawn avoided (fd close requested) DEBUG:netplan generated networkd configuration changed, restarting networkd DEBUG:enp65s0f0 not found in {} DEBUG:enp193s0f0 not found in {'enp65s0f0': {'addresses': ['10.1.11.230/24'], 'gateway4': '10.1.11.11', 'nameservers': {'addresses': ['10.1.11.11', '1.1.1.1']}}} DEBUG:enp193s0f1 not found in {'enp65s0f0': {'addresses': ['10.1.11.230/24'], 'gateway4': '10.1.11.11', 'nameservers': {'addresses': ['10.1.11.11', '1.1.1.1']}}, 'enp193s0f0': {'optional': True}} DEBUG:enp65s0f1 not found in {'enp65s0f0': {'addresses': ['10.1.11.230/24'], 'gateway4': '10.1.11.11', 'nameservers': {'addresses': ['10.1.11.11', '1.1.1.1']}}, 'enp193s0f0': {'optional': True}, 'enp193s0f1': {'optional': True}} DEBUG:br100 not found in {} DEBUG:br11 not found in {'br100': {'interfaces': ['vlan1']}} DEBUG:br240 not found in {'br100': {'interfaces': ['vlan1']}, 'br11': {'interfaces': ['vlan11']}} DEBUG:bond0 not found in {} DEBUG:vlan1 not found in {} DEBUG:vlan11 not found in {'vlan1': {'id': 1, 'link': 'bond0'}} DEBUG:vlan240 not found in {'vlan1': {'id': 1, 'link': 'bond0'}, 'vlan11': {'id': 11, 'link': 'bond0'}} DEBUG:Merged config: network: bonds: bond0: interfaces: - enp193s0f0 - enp193s0f1 - enp65s0f1 parameters: lacp-rate: fast mii-monitor-interval: 100 min-links: 1 mode: 802.3ad bridges: br100: interfaces: - vlan1 br11: interfaces: - vlan11 br240: interfaces: - vlan240 ethernets: enp193s0f0: optional: true enp193s0f1: optional: true enp65s0f0: addresses: - 10.1.11.230/24 gateway4: 10.1.11.11 nameservers: addresses: - 10.1.11.11 - 1.1.1.1 enp65s0f1: optional: true ovs_ports: {} vlans: vlan1: id: 1 link: bond0 vlan11: id: 11 link: bond0 vlan240: id: 240 link: bond0 wifis: {}
DEBUG:no netplan generated NM configuration exists DEBUG:enp65s0f0 not found in {} DEBUG:enp193s0f0 not found in {'enp65s0f0': {'addresses': ['10.1.11.230/24'], 'gateway4': '10.1.11.11', 'nameservers': {'addresses': ['10.1.11.11', '1.1.1.1']}}} DEBUG:enp193s0f1 not found in {'enp65s0f0': {'addresses': ['10.1.11.230/24'], 'gateway4': '10.1.11.11', 'nameservers': {'addresses': ['10.1.11.11', '1.1.1.1']}}, 'enp193s0f0': {'optional': True}} DEBUG:enp65s0f1 not found in {'enp65s0f0': {'addresses': ['10.1.11.230/24'], 'gateway4': '10.1.11.11', 'nameservers': {'addresses': ['10.1.11.11', '1.1.1.1']}}, 'enp193s0f0': {'optional': True}, 'enp193s0f1': {'optional': True}} DEBUG:br100 not found in {} DEBUG:br11 not found in {'br100': {'interfaces': ['vlan1']}} DEBUG:br240 not found in {'br100': {'interfaces': ['vlan1']}, 'br11': {'interfaces': ['vlan11']}} DEBUG:bond0 not found in {} DEBUG:vlan1 not found in {} DEBUG:vlan11 not found in {'vlan1': {'id': 1, 'link': 'bond0'}} DEBUG:vlan240 not found in {'vlan1': {'id': 1, 'link': 'bond0'}, 'vlan11': {'id': 11, 'link': 'bond0'}} DEBUG:Merged config: network: bonds: bond0: interfaces: - enp193s0f0 - enp193s0f1 - enp65s0f1 parameters: lacp-rate: fast mii-monitor-interval: 100 min-links: 1 mode: 802.3ad bridges: br100: interfaces: - vlan1 br11: interfaces: - vlan11 br240: interfaces: - vlan240 ethernets: enp193s0f0: optional: true enp193s0f1: optional: true enp65s0f0: addresses: - 10.1.11.230/24 gateway4: 10.1.11.11 nameservers: addresses: - 10.1.11.11 - 1.1.1.1 enp65s0f1: optional: true ovs_ports: {} vlans: vlan1: id: 1 link: bond0 vlan11: id: 11 link: bond0 vlan240: id: 240 link: bond0 wifis: {}
DEBUG:Skipping non-physical interface: lo DEBUG:device enp65s0f0 operstate is up, not changing DEBUG:Skipping composite member enp65s0f1 DEBUG:Skipping composite member enp193s0f0 DEBUG:Skipping composite member enp193s0f1 DEBUG:Skipping non-physical interface: bond0 DEBUG:Skipping non-physical interface: br100 DEBUG:Skipping non-physical interface: br11 DEBUG:Skipping non-physical interface: br240 DEBUG:Skipping non-physical interface: vlan.240 DEBUG:Skipping non-physical interface: vlan.11 DEBUG:Skipping non-physical interface: vlan.1 DEBUG:Skipping non-physical interface: virbr0 DEBUG:Skipping non-physical interface: virbr0-nic DEBUG:Skipping non-physical interface: vnet0 DEBUG:{} DEBUG:netplan triggering .link rules for lo DEBUG:netplan triggering .link rules for enp65s0f0 DEBUG:netplan triggering .link rules for enp65s0f1 DEBUG:netplan triggering .link rules for enp193s0f0 DEBUG:netplan triggering .link rules for enp193s0f1 DEBUG:netplan triggering .link rules for bond0 DEBUG:netplan triggering .link rules for br100 DEBUG:netplan triggering .link rules for br11 DEBUG:netplan triggering .link rules for br240 DEBUG:netplan triggering .link rules for vlan.240 DEBUG:netplan triggering .link rules for vlan.11 DEBUG:netplan triggering .link rules for vlan.1 DEBUG:netplan triggering .link rules for virbr0 DEBUG:netplan triggering .link rules for virbr0-nic DEBUG:netplan triggering .link rules for vnet0 DEBUG:enp65s0f0 not found in {} DEBUG:enp193s0f0 not found in {'enp65s0f0': {'addresses': ['10.1.11.230/24'], 'gateway4': '10.1.11.11', 'nameservers': {'addresses': ['10.1.11.11', '1.1.1.1']}}} DEBUG:enp193s0f1 not found in {'enp65s0f0': {'addresses': ['10.1.11.230/24'], 'gateway4': '10.1.11.11', 'nameservers': {'addresses': ['10.1.11.11', '1.1.1.1']}}, 'enp193s0f0': {'optional': True}} DEBUG:enp65s0f1 not found in {'enp65s0f0': {'addresses': ['10.1.11.230/24'], 'gateway4': '10.1.11.11', 'nameservers': {'addresses': ['10.1.11.11', '1.1.1.1']}}, 'enp193s0f0': {'optional': True}, 'enp193s0f1': {'optional': True}} DEBUG:br100 not found in {} DEBUG:br11 not found in {'br100': {'interfaces': ['vlan1']}} DEBUG:br240 not found in {'br100': {'interfaces': ['vlan1']}, 'br11': {'interfaces': ['vlan11']}} DEBUG:bond0 not found in {} DEBUG:vlan1 not found in {} DEBUG:vlan11 not found in {'vlan1': {'id': 1, 'link': 'bond0'}} DEBUG:vlan240 not found in {'vlan1': {'id': 1, 'link': 'bond0'}, 'vlan11': {'id': 11, 'link': 'bond0'}} DEBUG:Merged config: network: bonds: bond0: interfaces: - enp193s0f0 - enp193s0f1 - enp65s0f1 parameters: lacp-rate: fast mii-monitor-interval: 100 min-links: 1 mode: 802.3ad bridges: br100: interfaces: - vlan1 br11: interfaces: - vlan11 br240: interfaces: - vlan240 ethernets: enp193s0f0: optional: true enp193s0f1: optional: true enp65s0f0: addresses: - 10.1.11.230/24 gateway4: 10.1.11.11 nameservers: addresses: - 10.1.11.11 - 1.1.1.1 enp65s0f1: optional: true ovs_ports: {} vlans: vlan1: id: 1 link: bond0 vlan11: id: 11 link: bond0 vlan240: id: 240 link: bond0 wifis: {}
I am at the end of my options and ready to remove cloud-init/netplan and revert to the working configuration I had in 16.04. Thanks for reading this far.
Frank
I think your vlans are named incorrectly, they needs to contain interface name
  vlans:
    bond0.1:
      link: bond0
And I am assuming you removed addresses/dhcp on purpose from the example.
Update - sorry, I confused myself. You need to specify vlan number in bridge names, this is what is actually working for me (it is a virtual bridge for internal communication, no interfaces attached)
network:
  bridges:
    maasbr0:
      addresses: [ 10.244.40.1/21, ]
  vlans:
    maasbr0.2678:
      link: maasbr0
      addresses: [ 10.244.8.1/24 ]
    maasbr0.2733:
      link: maasbr0
      addresses: [ 192.168.33.1/25 ]
    maasbr0.2734:
      link: maasbr0
      addresses: [ 10.244.32.1/21 ]
    maasbr0.2735:
      link: maasbr0
      addresses: [ 192.168.35.1/26 ]
    maasbr0.2736:
      link: maasbr0
      addresses: [ 192.168.36.1/26 ]
marosg
  • 1,323
