-1
I have this partition:
  1. 50gb of NTFS (luckily i saved all data in that 50gb)
  2. 1.9 TB of Linux Swap (i think is empty)
  3. 50gb where is linux
I need to recover that 1.9 TB with a quick method even if it makes you lose the data inside because in theory it is empty.
ty for helps
Poiso
I generally assign about half of my RAM to a swap partition. This used to be recommended at least. So for my 8GB RAM on my desktop, I created a 4 GB swap.
As you've seen, yours is a little too big (!).
You can delete or resize the swap partition using the graphical program gparted. You might need to install it with sudo apt install gparted first.
There shouldn't be any "useful" i.e. user data in swap, it is a system partition.
colindaven
  • 104
