i have a device in my private network, let's call it "webserver". when i am directly connected to my private network at home then i can reach that server by using its host name, like http://webserver:1337. however if i connect to that network from a different network through VPN, like from work or from the library, my browser (firefox and chrome) can not resolve that hostname (both just using the system network configuration). if i run
dig webserver +short
i, don't get back an ip address. other hostnames however, like fritz.box (which is my router) do return the correct IP address.
dig fritz.box +short
192.168.178.1
so that makes me think that my VPN and DNS configurations are wrong and that i need to change them, because if i specifically ask my DNS server inside the VPN network, for that hostname, i actually get back the correct IP
> watch dig webserver @192.168.178.1 +short
192.168.178.46
in my VPN configuration the DNS server address is set to automatic so i assumed it would just retrieve the correct IP which looks like it should have worked, when i run
> systemd-resolve --status
Link 5 (tun0) Current Scopes: DNS
DefaultRoute setting: yes
LLMNR setting: yes
MulticastDNS setting: no
DNSOverTLS setting: no
DNSSEC setting: no
DNSSEC supported: no
Current DNS Server: 192.168.178.1 DNS Servers: 192.168.178.1 DNS Domain: ~.
Link 3 (wlp3s0) Current Scopes: none DefaultRoute setting: no
LLMNR setting: yes MulticastDNS setting: no
DNSSEC setting: no
my local /etc/resolv.conf also doesn't show any special configurations:
nameserver 127.0.0.53
options edns0
an if i run ip r i can also see that the route to the subnet with the nameserver, looks like it's setup correctly:
default dev tun0 proto static scope link metric 50
default via 192.168.0.1 dev wlp3s0 proto dhcp metric 600
169.254.0.0/16 dev wlp3s0 scope link metric 1000
192.168.0.0/24 dev wlp3s0 proto kernel scope link src 192.168.0.236 metric 600
192.168.0.1 dev wlp3s0 proto static scope link metric 600
192.168.178.0/24 dev tun0 proto kernel scope link src 192.168.178.201 metric 50
This is my VPN config file from /etc/NetworkManager/system-connections/
[connection]
id=**redacted**
uuid=**redacted**
type=vpn
autoconnect=false
permissions=user:**redacted**:;
timestamp=1604833427
[vpn] IKE DH Group=dh2 IPSec ID=redacted IPSec gateway=redacted IPSec secret-flags=1 Local Port=0 NAT Traversal Mode=natt Perfect Forward Secrecy=server Vendor=cisco Xauth password-flags=1 Xauth username=redacted ipsec-secret-type=save xauth-password-type=save service-type=org.freedesktop.NetworkManager.vpnc
[ipv4] dns-search= method=auto
[ipv6] addr-gen-mode=stable-privacy dns-search= method=auto
[proxy]
ifconfig tun0 gives me:
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1412
        inet 192.168.178.201  netmask 255.255.255.0  destination 192.168.178.201
        inet6 **redacted**  prefixlen 64  scopeid 0x20<link>
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 500  (UNSPEC)
        RX packets 3334  bytes 3091010 (3.0 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 2980  bytes 635324 (635.3 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
My systemd-resolved logs look mostly like this:
Dez 08 15:35:52 **redacted** systemd-resolved[1040]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
one noteworthy thing here is that /etc/resolv.conf points to /run/systemd/resolve/stub-resolv.conf, which contains
options edns0
some people suggest to just let it point to /run/systemd/resolve/resolv.conf, which contains:
nameserver 192.168.178.1
which IS the correct nameserver. but this would bypass resolved and can't be the solution to the problem.
i'd appreciate getting some pointers on how to further troubleshoot this issue. thanks in advance!
Did you try changing this to 192.168.178.1 (from what I gather that's your internal DNS server). Did you try to change your /etc/hosts just as a test and put in a line like:
192.168.178.1 webserver
(change IP and name to what they really should be)
LuxZg
  • 553
