My principal monitor defaults to 75Hz, but for some reason does not display anything when the frame rate is 75Hz on any of my devices (and OS). It does however work when changing to 60Hz.
I managed to lower the rate with Xrandr: xrandr --output DP-1 --rate 59.95 --mode 2560x1440.
The problem is that whenever I unplug the monitor, restart my computer or when it goes to screen saving, the frame rate is reset to its default (75Hz), not displaying anything.
Is there a way of changing its default rate?
I followed this thread, but for some reason I do not have a ~/.config/monitors.xml file.
Here is the output of xrandr:
Screen 0: minimum 320 x 200, current 2560 x 1440, maximum 16384 x 16384
DP-1 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 74.60 + 59.95*
1920x1200 59.95
1920x1080 60.00 50.00 59.94
1920x1080i 60.00 50.00 59.94
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1440x900 59.90
1366x768 59.79
1280x800 59.91
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
I assume the 'plus' sign is the default? Though I couldn't find a way of changing this in xrandr's manual.
