My system configuration is:
 1. 256 GB SSD (Win 10 installed)
 2. 2TB HDD (here I want to install Ubuntu with 200 GB space)
 3. UEFI + GPT
 4. Acer Predator Helios 3000
 5. 16GB RAM/ Intel Core i7 9th Gen/ 6GB Nvidia GTX 1660Ti
I have pre-installed Win 10 Home on my SSD. I want to install Ubuntu 20 LTS on my HDD with dual boot.
Here's what I have tried-
I have read lot of articles and came up with conclusion that the installation of Ubuntu could be proceeded as per the recommendation, with bootloader installed in SSD alongside Windows Boot-Loader in order to get the dual boot done.
My problem-
My system uses SATA Mode- RST Premium with Optane option while booting Windows. If I use this option, then my Ubuntu won't boot. If I set SATA Mode from RST Premium with Optane to AHCI, then Ubuntu gets booted but not Windows.
Here is where I need help. Previously while installing ubuntu, I had also tried to create an EFI partition in HDD, but that also had its own issue (only Ubuntu would boot; for Windows, I have to go again to BIOS and manually select boot option every time, or I have to do some mind-blowing coding in GRUB black screen to boot into Ubuntu some times. A lot of problems).
If its not a big issue, I want to keep the bootloaders of both the OS in SSD. However, I want to install Ubuntu in HDD and keep my Win10 in SSD. Also, after doing the installation, I want a simple dual boot screen from which I could easily boot either of the two OS. No more entering into the BIOS every time I have to toggle my OS.
Thanks for your answers.
Dual Boot Ubuntu 20 with Win 10 on Separate Disks
You do not need to install Ubuntu's bootloader on the same disk as Windows boot loader.
  • Assuming Windows boots in UEFI mode:
  • Unplug the Windows SSD before installing Ubuntu.
  • Boot Ubuntu install USB in UEFI mode.
  • Install Ubuntu.
  • Plug in Windows SSD.
  • Set Ubuntu HDD as first hard drive.
  • Boot Ubuntu and run sudo update-grub to add Windows to Ubuntu's bootloader menu.
This method will preserve the Windows bootloader on the SSD in case the HDD is ever moved or replaced.
C.S.Cameron
  • 20,530
  • 78
  • 125
