Make a Permanent Change on a Persistent Live USB
Programs like Etcher, Win32DiskImager, dd, Gnome-Disks and Startup Disk Creator, create a USB with a read only operating system with a read only bootloader.
Other Programs like Rufus, Ventoy, mkusb, UNetbootin and YUMI create a USB with a Syslinux or GRUB bootloader config file that can be edited regardless if the USB is Persistent or not.
Rufus Windows:
If you are working from Windows, use Rufus to create your Live or Persistent USB.
Use the Write ISO image option, (Default), if asked.
While still in Windows Edit /boot/grub/grub.cfg. adding radeon.modeset=0 after quiet splash in the first menuentry.
Then Edit /isolinux/txt.cfg adding radeon.modeset=0 after quiet splash in the first menu item.
Mkusb Ubuntu
If you are working from Ubuntu use mkusb to create a persistent USB with your preferred options.
Using disks, mount the USB's usbboot partition.
This should set you up permanently for both BIOS and UEFI boots whether the USB is Live or Persistent.
