When I try to install a package, for example firefox, using:
sudo apt install firefox
I get asked for entering my password. After entering it, I get:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libglvnd-dev : Depends: libgles-dev (>= 1.3.0-1) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I enter:
sudo apt --fix-broken install
as the error output suggests, but I get:
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
libglvnd-core-dev libx11-xcb-dev libxcb-dri2-0-dev libxcb-dri3-dev
libxcb-glx0-dev libxdamage-dev libxshmfence-dev x11proto-damage-dev
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libgles-dev
The following NEW packages will be installed:
libgles-dev
0 upgraded, 1 newly installed, 0 to remove and 707 not upgraded.
4 not fully installed or removed.
Need to get 0 B/50.4 kB of archives.
After this operation, 718 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 354422 files and directories currently installed.)
Preparing to unpack .../libgles-dev_1.3.2-1~kisak~b_amd64.deb ...
Unpacking libgles-dev:amd64 (1.3.2-1~kisak~b) ...
dpkg: error processing archive /var/cache/apt/archives/libgles-dev_1.3.2-1~kisak~b_amd64.deb (--unpack):
trying to overwrite '/usr/include/GLES2/gl2.h', which is also in package libgles2-mesa-dev:amd64 20.0.8-0ubuntu1~18.04.1
When I enter:
sudo apt-cache policy libgles-dev libgles2-mesa-dev
the output shows:
libgles-dev:
Installed: (none)
Candidate: 1.3.2-1~kisak~b
Version table:
1.3.2-1~kisak~b 500
500 ppa.launchpad.net/kisak/kisak-mesa/ubuntu bionic/main amd64 Packages
libgles2-mesa-dev:
Installed: 20.0.8-0ubuntu1~18.04.1
Candidate: 20.2.1~kisak1~b
Version table:
20.2.1~kisak1~b 500
500 ppa.launchpad.net/kisak/kisak-mesa/ubuntu bionic/main amd64 Packages ***
20.0.8-0ubuntu1~18.04.1 500
500 in.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages
100 /var/lib/dpkg/status 19.2.8-0ubuntu0~18.04.2 500
500 security.ubuntu.com/ubuntu bionic-security/main amd64 Packages
18.0.0~rc5-1ubuntu1 500 500 in.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
What should I do?
